Offroad & 4x4
diff breather
Old Jan 5, 2007 | 01:06 AM
kjg26's Avatar
kjg26
diff breather
has anyone on here lengthened the breathers on your diffs? where'd you lengthen them to? the front is fairly obvious.... but the rear? just tuck itup as high as i can under the bed? what did you use to lengthen them? oh... this is an 89 f150 dana 44 up front and 8.8 in the rear.
thanks
keith
Old Jan 5, 2007 | 01:09 AM
fishmanndotcom's Avatar
fishmanndotcom
i bought a spool of rubber hose (it was like $.20 a foot) but i ran them all the way in the cab. drilled holes in the floor and ran them up in the top of the cab in the corner. worked very well and never had a water problem!
-cutts-
Old Jan 5, 2007 | 06:23 AM
quadzjr's Avatar
quadzjr
just another Rockwell looser
I did close to the same thing, except i didn't want to drill in my body so fed it between the bed and the cab and drilled a hole into my toolbox, and put it in there, worked great, never had a problem yet.
Old Jan 5, 2007 | 10:32 AM
75F350's Avatar
75F350
Ditto for the in cab mounted breathers, the ones for the t-case, and the trans also reside in there too. Don't forget those.
Old Jan 5, 2007 | 10:35 AM
kjg26's Avatar
kjg26
do you just use a hose barb to extend the tubing? and do you have to worry about any smells coming from the breathers? diff fluid is nasty stuff
Old Jan 5, 2007 | 10:41 AM
75F350's Avatar
75F350
I made all new hoses, (ss braided) and ss fittings. I like to be able to remove the hoses when it is time to remove the component. Those crazy long hoses seem to always get in the way. But you could use anything you want, as long as it will not pop off, or let any water in. As far as the smell goes, I have never noticed that gear oil stink, the only odor in my truck, is the sweet smell of VP C14! OOOOH Yeah........
Old Jan 5, 2007 | 12:40 PM
kjg26's Avatar
kjg26
you said u used all new hoses and fitings... how does the factory vent tube connectto the diff? and how does yours connect to the diff?
Old Jan 5, 2007 | 01:59 PM
chrono4's Avatar
chrono4
the factory ones are just a little hose barb. just put the new hose on there with a clamp and it will be good.
Old Jan 5, 2007 | 02:31 PM
kjg26's Avatar
kjg26
k sounds good.
thanks
Old Jan 5, 2007 | 04:43 PM
unrulee's Avatar
unrulee
Maybe you could run it up one of the stake pockets? I'm not sure, but that's what I'd try.
Old Jan 5, 2007 | 05:05 PM
rebocardo's Avatar
rebocardo
On my BII, behind the rear driver qtr trim panel for the rear axle and engine compartment for the front.
Considering on many Fords the transmission and transfer case share one breather, that would be the one to spend a lot of time relocating. Up into the pillar post, at least on a BII, is good because there is a drain hole/hose there anyway.
Greg5OH
Aug 19, 2014 03:35 PM
pitbull62
Dec 18, 2013 06:34 PM
Stinky7-11
33
Jul 20, 2013 11:10 AM
crazed87bronco
Jun 22, 2011 12:49 AM
82ford302
Offroad & 4x4
23
Mar 13, 2010 02:00 PM
