Modular V10 (6.8l)
Installing a Block Heater
Old Jan 19, 2007 | 12:43 PM
PROSTOCK's Avatar
PROSTOCK
Originally Posted by Fredvon4
Prostock
I have a chunk of property on lake Brownwood... maybe this sumer we can stop together at Humphrey Petes for a brew and BS
I have a ski boat, a new-to-me V10 "X", and enthusiastically enjoy "brews"...we need to talk!
Old Jan 27, 2007 | 11:51 AM
Jack_99V10's Avatar
Jack_99V10
I'm back, because it has been in single digits for the last couple nights here in WNY.
I have a block heater on my 99 F250, V10... will it actually help the vehicle heat up in the morning? If so, can I plug it in when I get up, and by the time I'm out of the shower, and out for work my truck will be ready for me without having to walk outside in the snow and wind to start it and let it warm up? That would be great...
Old Jan 30, 2007 | 04:26 PM
PROSTOCK's Avatar
PROSTOCK
Your close, for heat out of the heater it will be nearly instant, but not real hot. It takes my old '65 390 about 2 - 3 hours to get warm, but that is very dependant on the outside temp and wind.
Put a good timer on it and try it out. I'd start with at least a 2 hour period, and you can experiment from there.
A bonus is dramatically reduced emissions and engine wear at start-up.
Old Jan 30, 2007 | 06:41 PM
Fredvon4's Avatar
Fredvon4
Why not just plug her in when you park of the night?
I do this each and every night when we dip below 40 most of the time the energy costs are not noticeable on the bill,,,, these are not 1500 watt wall heaters..they do not draw many amps at all.
My coolant is not hot in the morning but the heater will blow warm air by the end of the drive way and the pre heated block dramatically reduces the cold idle time saving fuel and the motor.
The giant V10 and the puny block heater will need at least three hours in the morning depending on how cold it is over night...
Try it my way one night and your way the next and see what works for you best
Old Feb 5, 2007 | 04:49 PM
TRX250R87's Avatar
TRX250R87
block heater
I have a 5.4L here in Wisconsin. The past week has been GOD AWFUL COLD! It wa -18*F this morning and the F150 did not start How many watts and amps are the stock engine block heaters? I just want to know if I should get a timer, if so will a 15A timer work, or just plug it in before bedtime?
ERIC
Old Feb 6, 2007 | 07:41 PM
rwetter's Avatar
rwetter
The V10 Ford block heater is only 750 watts, in the below 10 degree weather I leave it on all night.
Got a timer to use on lesser cold days that is rated 20amps so not a problem for most any block heater. I usually set it for 4 hours.
.r
Old Feb 6, 2007 | 10:33 PM
TRX250R87's Avatar
TRX250R87
block heater
I finally called my dealer today and they said it was 600 watts. So at $.125/kw hour I can run it 4 hours every morning for about $.25 per day.
ERIC
Old Feb 7, 2007 | 08:27 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
$.125/kwh ... sheesh... I'm movin'!
Old Feb 7, 2007 | 08:46 AM
TRX250R87's Avatar
TRX250R87
Is that low? I remember when it was about .07
ERIC
Old Feb 10, 2007 | 04:22 PM
Louis Amsler's Avatar
Louis Amsler
block heater
My brother has a k10 chev with a mileage computer. He noticed his mileage is horrible until it makes closed loop. Somebody out there should study this with a V10 who has a computer option- ( I don't ). I bet a heater would pay off, even here in LIPA land (Long Island), because my mileage nosedives in the cold weather. If we are doing good at 12 in the summer, and 8 in the winter, what could the mileage be while it is warming up?
Old Feb 10, 2007 | 06:48 PM
Fredvon4's Avatar
Fredvon4
Louis.... in the winter months mine is better over all with a pre heated truck so I assume your observation is valid.... quicker into lean fire mode without extra cold air enrichment
Old Feb 10, 2007 | 09:59 PM
krewat's Avatar
krewat
At $.1763 (that's both power supply charges - $.0976/Kwh, and delivery and system charges - .0787/Kwh) per Kwh...
A 600 watt heater, which is .6 Kwh (Kilowatts per hour).
Four hours to heat up.
20 business days per month.
.6*4*20 = 48Kwh. 48Khw @ $.1763 = $8.46
Not bad... wow... I'm starting to think it might be a very good idea. Starting? I'm CONVINCED...
Someone said .9 gallons per hour idling for a V10.
Figure I run it 15 minutes before I get in it to "warm it up". 20 days a month.
That's 15*20 = 300 minutes = 5 hours @ .9 gallons = 4.5 gallons @ $2.35 = $10.58
$8.46 to warm it up with a block heater for four hours. (here in LIPA-land, one of the highest electric rates in the nation)
$10.58 to warm it up with gasoline.
If your cost per Kwh is low enough, it makes a whole lot of sense. For me, I'd have to install a block heater. And I'd still not have total heat like I do after 15 minutes.
How hot would the coolant get after 4 hours when the outside temp is 20 degrees?
Old Feb 21, 2007 | 06:36 PM
  #28
Jack_99V10's Avatar
Jack_99V10
20 degrees? lol... we are finally above 20 degrees out there. I've had my window down, and it is only like 35 now
slim613
29
Oct 7, 2011 11:00 PM
Tim Young
47
Jun 11, 2011 12:23 PM
Kapusta
43
Dec 27, 2010 08:17 PM
maevans
Jan 1, 2009 11:56 AM
brown 4x4
Nov 29, 2007 06:45 AM
