Multiple EGT gauges/ boost cooler
Old Jan 4, 2007 | 10:22 AM
dzzavid's Avatar
dzzavid
Arrow Multiple EGT gauges/ boost cooler
i currently have an EGT gauge installed in my exhaust manifold, i am in the process of planning my install of the snow performance stage 3 boost cooler
i have 2 basic questions.
1) will multiple EGT gauges cause turbulance and lower performance?
2) shoudl i run water injection through the intercooler? if not which side is the air that is going into the intake after it has been intercooled?
99.5 f250 7.3
thank you
-dave
Old Jan 4, 2007 | 10:30 AM
CSIPSD's Avatar
CSIPSD
Run your water injection after the IC, you can drill and tap the IC tubes or the Y pipe. I did the Y pipe. You will not hurt anything with a second pyro, you could always install it on the pass side too.
Did I talk to you about the cooling mist stage 3 kit? Much nicer looking then the snows? www.coolingmist.com
There kit looks alot cleaner and you get the PDA... Just a FYI... There is nothing wrong with the snows kit, I just dont like the look of that box...
Old Jan 4, 2007 | 10:33 AM
tjbeggs's Avatar
tjbeggs
multiply gauge should not cause any issue. they take up very little room in the exhasut system. also I would run the water post intercooler. I would be concern about the water condensing in the IC from the temp drop. I have no experience with water injection so my comments are just from what I THINK would be right.
Old Jan 4, 2007 | 11:39 AM
dzzavid's Avatar
dzzavid
thank you,
and yes i belive you did, i dont liek the look of the box either , that is why i am keeping my gauge pod heh, i am going to see how much better performance i get out of water injection if it is a lot then i will sell my kit and upgrade to the cooling mist
thanks again!
dzzavid's Avatar
dzzavid
that is what i thought as well, thanks you for the advice
Old Jan 4, 2007 | 11:45 AM
CSIPSD's Avatar
CSIPSD
If you need any install help feel free to PM me!
Old Mar 10, 2007 | 02:01 PM
dzzavid's Avatar
dzzavid
Can i run two gauges on one pryo sensor?
Old Mar 11, 2007 | 12:00 AM
CSIPSD's Avatar
CSIPSD
I dont know... they work like a volts gauge so too much draw on one might make both read too low???
Old Mar 11, 2007 | 12:03 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Install the jet in the passenger side intercooler pipe, or remove the compressor manifold and install it in the neck that attaches to the passenger IC pipe.
