57 VIN location
Old Jan 3, 2007 | 11:29 PM
Snowking's Avatar
Snowking
57 VIN location
I can't find a VIN number to my 57. I thought it was supposed to be on the driver dor but mine is not. I found the s/n GVW axle paint tag on the front side of the driver doo. No it is not on the glove box door. My driver door rubes so I worry it may have worn off.
Any help appreciated Ryan
Old Jan 4, 2007 | 01:19 AM
Fomoko1's Avatar
Fomoko1
a quick vin location search...
I did a quick search and from previous threads found up this: https://www.ford-trucks.com/forums/5...f250+frame+vin
Old Jan 4, 2007 | 01:41 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Exclamation
I found the s/n GVW axle paint tag on the front side of the driver door. Any help appreciated Ryan
That should be it...VIN's do not remotely resemble what's on vehicles today.
Parts Book states location is: Left front cab pillar (if not inside glove box door).
Old Jan 4, 2007 | 02:18 AM
WillyB's Avatar
WillyB
It should be on the inside of the glove box door - if that has been lost it is stamped on the frame in two places. Both locations are on the top of the right frame rail, one in front of the cab mount, the other behind.
They can be very hard to spot - I used a wire brush and thinner to bring mine out. I also had the chassis removed. Other people have told me that sometimes the production line would stamp the frames closer to the radiator support, one even said it had been stamped into the front crossmember.
Old Jan 4, 2007 | 01:49 PM
dixiefried's Avatar
dixiefried
mine is on the drivers side under the door catch along with the paint and axle codes
Old Jan 5, 2007 | 01:26 PM
Snowking's Avatar
Snowking
Um are you measning the frame just n front of the cab mount on the passenger side. Is it on the top of the beam facing ouside facing inside or eneath I still could not find it.
Sorry for being stupid.
Old Jan 5, 2007 | 01:44 PM
Fomoko1's Avatar
Fomoko1
All of mine VIN were on top of the frame top rail flange, it could be anywhere and doesn`t seem to be in any consistant location. It is very, very hard to see.
While it helped to find the stamping by sandblasting it`s still very hard to see it even then, the stamping is not deep and really it`s too faintly done. Seems they didn`t want you to find it.
ryan f150 4x4
Jul 26, 2021 07:45 AM
millertme
18
Jan 4, 2014 10:56 PM
jmm
Jan 11, 2008 07:31 PM
transworldmotors
Apr 5, 2006 01:23 PM
jjoker023
Apr 24, 2004 10:07 AM
