57 vin location?
Old Jan 2, 2014 | 04:06 PM
millertme's Avatar
millertme
57 vin location?
Hey Guys! I am playing the game trying to get my 57 back on the road after resting in Texas since 94... While going through the vehicle inspection, DMV noticed the vin tag on the driver door jam was missing and is now have to visit CHP for a new replacement (flagged). Before I go in for, are there any other locations I am missing where the cab vin tag should be located on a 57?
1. Passenger frame rail
2. Driver door B pillar next to latch (vin missing, rivot holes showing)
3. Glovebox sticker?? (painted over unfortunately)
4. ?
Thanks in Advance!
Old Jan 2, 2014 | 04:10 PM
MARC's Avatar
MARC
vin is on inside of glovebox door
Old Jan 2, 2014 | 04:15 PM
millertme's Avatar
millertme
Hey Marc. Thanks for the prompt reply!
I can see where the vin sticker is on the glovebox door however it has two coats of paint. Do you happen to have an example of what the sticker should look like so I can carefully scrape the area where the vin is?
Thx
Old Jan 2, 2014 | 04:18 PM
millertme's Avatar
millertme
found one on ebay... Perfect! I'll get to paint removal today
Old Jan 2, 2014 | 04:20 PM
MARC's Avatar
MARC
should be a pop riveted metal plate. Do a search for vin # info, I have seen several vin plates posted on this site.
Marc
Old Jan 2, 2014 | 04:22 PM
MARC's Avatar
MARC
photograph it first, then try water, see if it will bubble up with water, I would put a wet wash cloth on it for about 10-15 minutes to see if it will soften or loosen
Old Jan 2, 2014 | 04:33 PM
Choptopjimmy's Avatar
Choptopjimmy
Why don't you just look at the VIN on top of the passenger side frame rail right in front of the cab? Jim
Old Jan 2, 2014 | 04:47 PM
millertme's Avatar
millertme
CHP requires two vin marking. Frame and Cab. No problem with the frame tag it's just the cab is missing from the driver door sill.
Hey, from the picture it looks like the glovebox tag is rivoted on. Is that right?
Old Jan 2, 2014 | 05:00 PM
Choptopjimmy
Yes. As Marc pointed out earlier, it is riveted to the glove box door. Jim
Old Jan 2, 2014 | 07:04 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Hey, from the picture it looks like the glovebox tag is riveted on. Is that right?
Notice that there are two possible locations for the Rating Plate.
Left front cab pillar aka windshield post. If Rating Plate is located here, it's visible when the door is opened.
Old Jan 2, 2014 | 08:17 PM
millertme's Avatar
millertme
Looks like I'm SOL! Tag on the glovebox is the recommended engine sticker. Not seeing any rivet holes or potential fill holes outside of the driver B pillar. Thanks again guys. I appreciate the extra support on this.
Missing tag location:
Old Jan 3, 2014 | 02:38 AM
NumberDummy
B pillar is where the striker plate is located, A pillar is windshield post, above the door jamb where the hinges are located.
Old Jan 3, 2014 | 08:46 AM
a4t1rat's Avatar
a4t1rat
I have a really early production 57 and the tag is located on the passenger side b pillar by the door latch striker plate, might try there?
Old Jan 3, 2014 | 10:55 PM
Danleig's Avatar
Danleig
Hmmm, my '57 also has the tag on passenger B pillar.
I was wondering what constitutes "early production?" My production sequence # is 30564, and while I was poking around he Internet to try and answer my own question, I found this interesting site for fridges;
HowStuffWorks "1957-1960 Ford F-Series Specifications"
Old Jan 3, 2014 | 11:18 PM
millertme's Avatar
millertme
How cool is that! To be honest with you, it looks like the cab was resprayed 20+ years ago and the vin plate was pulled from the only visible location (Driver door jam near striker, not hinge).
Why there are no rivet provisions inside the glovebox, Driver A Pillar, or passenger sill… Still no clue :-/
