back to fte after walk about...new 88 f150 question
good morning and i just traded a well sorted 78 f100 swb 2wd for a 1988 f150 swb 4wd. its has issues and i need some advice please. 1. it spark knocks extremely bad at part throttle.........i'm thinking egr. it hunts idle.... thinking tps. the third need is the fuel gauge the needle floats to both full and empty regardless of the amount of fuel. any help would be greatly appreciated. thanks teschwab
pulled codes, but a funny deal happened....
prior to pulling the codes i started to check timing. pulled the sprout connector and loosened the distributor hold down. then as i laid my hand on the distributor to make a slight adjustment. the ole' girl shut down and will not fire up. engine cranks over fine just no fire in the holes. so i pulled the codes and it revealed code 14 pip circuit failure and 84 egr vac solenoid circuit failure and 21 ect, 33 egr valve opening not detected. my original post pertained to spark knock. the pip code explains the no fire deal, but could the pip problem begin with module. any idea's thanks tim
