horrible mileage
Old Jan 13, 2007 | 09:10 PM
  #31
98sexpo02gata's Avatar
98sexpo02gata
what did u do to it? my expo doesnt get but 12
Old Jan 14, 2007 | 01:27 AM
  #32
slenser's Avatar
slenser
Johnny, can you tell me what all you have done to your Navigator?
I'm currently getting 13 MPG on my 2000 Navi. I've changed air filter just recently to a Fram Air Hog and will be replacing the fuel filter as soon as it warms up around here. Spark Plugs are next, but I don't know if I should do it myself or take it to the dealer for fear of the COPs breaking. New fluids after that. This beast has just over 100K on it and I have no idea if anything has been done to it before me.
Any help would be appreciated!
Thanks,
Sam
Old Jan 14, 2007 | 06:15 AM
  #33
High_Horse's Avatar
High_Horse
Slenser, is yours a 2x4 or 4x4? I have a 97 2x4 w/5.4 and get around 18-20 w/450k on her.
First off, synthetic oil would be #1, plugs are about due, I usually do mine around 110k. Though your lack of mileage indicates they may be due now. I use a K&N air filter. You won't break the COPS, but working on them in the cold my feel like your breaking your fingers. The dealer will get ya for around $350 to do the plugs. Plus the only dealer who worked on my truck didn't even put the correct screw back in for the replacement of a single cop. That was the last dealer to touch my truck 8 yrs ago.
Replacing plugs is just a matter of patience, takes me around 2.5-3 hrs to do mine. But then again, I'm in sunny warm FLA.
Make sure when you pull the cop off the plug to blow out the recess before removing the plug so as not to get crud into the threads (possibly crossthreading) or into the cylinder head. All it takes is a quick shot, I put a 3/16 vacuum hose on my air nozzle about 16" long to make it easy to direct the air into the recess.
Old Jan 14, 2007 | 06:21 AM
  #34
hookd's Avatar
hookd
Anybody have a write up on changing the plugs? from what I eard you damned near had to tear apart the front end to get to the #4 and #8.
Thanks
Old Jan 14, 2007 | 06:32 AM
  #35
High_Horse's Avatar
High_Horse
There tight, but that's where the patience comes in...
...on each plug you will need to disconnect the fuel injector pulse connection and the connection to the cop to give you clearance to get to the retaining screw (8mm). On #4 I use short box/open end wrench, it may take some time but its not that bad. You'll get more dirty from the hoses than anything. On #8 I use a swivel on my 1/4" drive to loosen it and finish removing it with the box/open. The #7 is under a, I think, pressure regulator on the fuel rail. I haven't had to remove the fuel rail, but had to loosen the two bolts to get a bit of movement to get the cop out. The rest are a piece of cake, that's why I personally start with those three to gettem' out of the way.
Old Jan 14, 2007 | 11:12 AM
  #36
hookd's Avatar
hookd
Thanks man sounds like I could get it just need to find a warm spot to work in
Old Jan 14, 2007 | 02:09 PM
  #37
Johnny Langton's Avatar
Johnny Langton
The 32V modulars are extremely efficient-the slow burn combustion chamber can handle alot of ignition timg,and also a lean fuel mixture.These things along with more EGR dialed into the tune make for a fuel efficient engine while cruising,and much more power when at WOT. I just filled it up today and checked the mileage again after the wife has been driving it all week.
392 miles / 21.2 gallons=18.49 mpg. That's in mixed driving with about 60% highway and 40% in town.
The OEM tunes on these vehicles is pretty bad-they're very rich with very little timing advance(esp the 87 octane tuned 5.4L 16V's),and minimal EGR. There are a few more things,but those are the biggest keys to fuel economy.
JL
Old Jan 14, 2007 | 02:11 PM
  #38
Johnny Langton
Thanks,
Sam
Like I said in the previous post..it's all in tuning and getting the engine to run as efficient as possible.
JL
Old Jan 14, 2007 | 03:08 PM
  #39
amm888's Avatar
amm888
JL
do you think similar timing/EGR tweaks would lead to similar results in a 16 valve 5.4?
Old Jan 14, 2007 | 03:48 PM
  #40
Johnny Langton
The 16V is severely limited by the amount of spark that it can run-the intake is so restrictive that it makes it very,very knock prone.But,a good tune will make a world of difference in the fuel mileage and power of them.I'll clip some screenshots of the base spark tables of each when I get back home tonight for comparison.
JL
Old Jan 14, 2007 | 04:00 PM
  #41
slenser's Avatar
slenser
I guess I was wondering what the "SCT EEC reflash" was that you have in your signature.
Sam
Old Jan 14, 2007 | 09:11 PM
  #42
Johnny Langton
Here's a comparison of the OEM Spark tables for a 32V vs a 16V.
The top table is the spark table from my Navigator's 32V,the bottom table is from a 16V.
This is only one of the reasons the 32V engines are more efficient-allowing more ignition timing advance at cruising speeds makes more torque,and keeps the engine from going in to open loop fuel from high load when you have to tip into the throttle for maintaining speed.
For the best economy and power,a competent tuner with the proper tools can make a world of difference.IMO,you can't get better than SCT for software and hardware on Fords,but you must be careful to choose a good tuner than uses SCT software and hardware. there are some hacks out there that couldn't tune a lawnmower,much less your vehicle.
JL
Old Jan 15, 2007 | 11:20 AM
  #43
amm888's Avatar
amm888
thanks for the tables JL, unfortunately we're in completely different leagues, mechanically, and I really don't get what they're showing. looks like i'll have to do some research.
al
Old Jan 15, 2007 | 12:27 PM
  #44
Johnny Langton
al
What you're looking at:
The left hand column up and down is the percent load (.89=89%,.79=79%,etc,etc).
The column across the top is engine RPM,and the values in the table are degree of ignition timing advanced or retarded from TDC.
So,for example...my Navigator's spark value for cruising speed is found by taking the rpm(2000 for me at approx 70mph),and load it sees(approx 40% load at cruising on flat land),and finding the corresponding value in the table. In that particular case,the EEC is going to command 39 degrees of ignition timing advance before any other corrections are does to that value.
A 2V at the same load and RPM is only going to get 30 degrees of advance.
Now,this is only part of the calculation,but it's where it all starts. This is also why it's so important not to screw around with the MAF. The MAF is one of the main pieces of the load calculation puzzle,and if it's wrong,then the EEC simply uses the incorrect spark value for the vehicle at that time. That can mean a weak engine from lack of spark advance,or a knocking/pinging one from too much advance.
JL
Old Jan 15, 2007 | 06:22 PM
  #45
slenser's Avatar
slenser
OK, after some searching I found out what SCT stands for... Superchips Custum Tuning.
Now, what model of SCT do you have? Is it custom tuned for your truck? Is it a canned program in the tuner that I would have available if I purchased the same tuner as you?
BTW High_Horse, I have an AWD/4X4 so I know that will diminish my mileage some, but my 2001 Navi was getting 18MPG on trips versus the 13.4 I'm getting now. That's why I'm looking at replacing stuff before buying the tuner. I think the winter mix is killing a lot of the efficiency right now as well. Anyone know on average how much mileage is lost once they change over? I haven't been keeping track.
My goal is 20+MPG
Sam
