Tailgate Cables for 78f150 shortbed
Old Jan 3, 2007 | 04:11 AM
honkytonk's Avatar
honkytonk
1978 f150 4x4 Shortbed
I know this might be a silly question but I have been looking at alot of Parts websites and never am able to find Tailgate Cables for my truck to keep the new tailgate from flopping all the way open. Anyone know an easy website/place to get them?
Also, if you know how I can get my truck info to post automatically at the bottom of my posts like an email signature, let me know that as well. Ive been through my profile and cant find the option
many thanks
Old Jan 3, 2007 | 04:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Question ?
many thanks
Does your truck have a Flareside (outside fenders) or Styleside bed?
Old Jan 3, 2007 | 04:57 AM
honkytonk's Avatar
honkytonk
It is the Styleside model. I guess its not cables I need but the Arm Parts. I can never seem to find just those and not the whole tailgate and assembly
Old Jan 3, 2007 | 05:09 AM
NumberDummy
The good news is the Styleside uses the same arms from 1964 to 1979. Where the tailgate latches on the rear, are there any oblong rectangular pieces the metal straps fit on? (Sorry I'm using a microfiche reader, so I can't scan and post pics).
Can you post a pic in your member gallery...from that, I can advise you what you need.
Old Jan 3, 2007 | 05:26 AM
NumberDummy
Exclamation T/gate supports
C4TZ-9944400-A Strap, tailgate (2)
C4TZ-9944482-A bumper, tailgate (2)
C4TZ-99431B54-A Bracket, to body tailgate strap mounting (2)
This oughta fix you up...these parts were available from Ford not all that long ago. Try some FTE suppliers here.
Old Jan 3, 2007 | 05:32 AM
honkytonk's Avatar
honkytonk
NumberDummy. Its at home and Im at work so I'll have to take some photos of the truck when I get there in a couple of hours and Ill try to have them up on my profile or somewhere by 11AM EST Wed, Jan3.
Basically I just need Arms, Cables, or whatever else anyone thinks will work and the best place to buy them. All I can seem to find is one person selling a rusty pair on Ebay.
Old Jan 3, 2007 | 05:36 AM
NumberDummy
I posted the parts numbers above ^^^^this should take care of it. Your local dealer will have pics...take the numbers I posted with you...you may still be able to get them from Ford.
Old Jan 3, 2007 | 08:49 AM
samickguy15's Avatar
samickguy15
Our trucks use the metal arms. I just bend the set on the truck I'm getting rid of other wise I would have sent them to you for cost. Only one side is a little bent. You could probably straighten it out rather easily. They're not rusty either...
Old Jan 3, 2007 | 10:42 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Here is a diagram of what the parts look like that you need.
Old Jan 3, 2007 | 11:24 AM
timothy47129's Avatar
timothy47129
Is there any swap to use the cable style off the 199ish trucks?
Old Jan 3, 2007 | 12:23 PM
samickguy15
Well...I don't know why you would want to, but the only difference I would see would be the mounting points, where you could probably weld or bolt on the newer cable style mounts.
Old Jan 3, 2007 | 12:27 PM
81-F-150-Explorer
The Cables off of a 1983 and newer truck, would not have the tensile strength to hold the larger heavier tailgate up, IMO.
Oh, and a little off topic question for numberdummy...
Mr. Numberdummy, do you know the part numbers of the tailgate straps for the 1980 to 1982 trucks? They look simular to the 73-79's etc, only inverted. Would be nice if they are the same ones too.
Old Jan 3, 2007 | 11:06 PM
NumberDummy
Exclamation
My part numbers are correct...but the word "straps' was not a good choice of words.
1964-1979
C4TZ-9944400-A ...ARM, TAILGATE
C4TZ-99431B54-A ..BRACKET, TAILGATE ARM
C4TZ-9944482-A ..BUMPER, RUBBER, TAILGATE
Old Jan 3, 2007 | 11:52 PM
Mil1ion's Avatar
Mil1ion
The main part will be prtetty close to the ones above.
If they were differently designed for the 80 truck but would be close beause of the job they do..
The part number would be something E0TZ-994410-A
or do you mean these at the top of the page?
http://blueovaltruckparts.com/catalo...oducts_id=6340
or these for 83-86
http://blueovaltruckparts.com/catalo...oducts_id=6332
Old Jan 4, 2007 | 12:00 AM
NumberDummy
Exclamation T/Gate Arms 1980-86
Originally Posted by 81-F-150-Explorer
Oh, and a little off topic question for numberdummy...do you know the part numbers of the tailgate straps for the 1980 to 1982 trucks? They look simular to the 73-79's etc, only inverted. Would be nice if they are the same ones too.
The 1980/ tailgate arms are different than 1964-79 & inc brkts.
1980 thru 1982 ONLY
1 each: E2TZ-99431D76-A : Arm and Bracket, Tailgate R/Side
1 each: E2TZ-99431D77-A : Arm and Bracket, Tailgate L/Side
1983 thru 1986 ONLY
E3TZ-99431D76-A Arm and Bracket, tailgate, R/L
