Computer Chips & Tuners
code PO604 help
Old Jan 3, 2007 | 02:16 AM
toolboxjunky's Avatar
toolboxjunky
Question code PO604 help
can't get rid of code po604 KAM memory looked at everything PO605 is pcm failure can't run any more diagonistics till this is fixed! do i just need to replace the pcm and be done with or what?
Old Jan 3, 2007 | 06:08 PM
CSIPSD's Avatar
CSIPSD
604 is a normal code when ever you clear the codes or unhook the batterys... It is Keep Alive Memory... KAM... Nothing wrong with your computer... at least not from that code.
Old Jan 4, 2007 | 06:40 PM
ReAX's Avatar
ReAX
Can your scanner clear codes? Try clearing and rereading them.
Old Jan 9, 2007 | 11:56 AM
CSIPSD's Avatar
CSIPSD
You can clear it a hundred times the KAM will always come back.
Dstosh
Oct 24, 2016 01:29 PM
Jim40216
Sep 8, 2016 01:52 PM
bkollmeyer
Mar 19, 2015 06:09 AM
reality_check
Apr 18, 2013 11:31 PM
mrswift
May 10, 2010 12:44 PM
