HPO Reservior
Old Jan 2, 2007 | 11:04 PM
cdiddy's Avatar
cdiddy
HPO Reservior
How do you check the HPO reservior? Where is the reservior and should I be checking this on a regular basis?
Old Jan 2, 2007 | 11:36 PM
670johndeere's Avatar
670johndeere
The reservior is located under the Powerstroke cover, and there is an allen plug that you remove to see the level. I believe it should be around 3/4 full. I'm not really sure on how often you should check this.
Old Jan 3, 2007 | 01:27 AM
toolboxjunky's Avatar
toolboxjunky
Question hpo inspection why?
why are you wanting to inspect the reservoir what problem are you having?
Old Jan 3, 2007 | 05:13 AM
Tenn01PSD350's Avatar
Tenn01PSD350
No, you do not need to check this regularly unless you are having a problem with your injectors during cold starts. If you want to check it, it is the allen head plug on top of the reservior and the oil should be about 1/2" from the top. If it is more than one inch then your check valve may be malfuncioning. Oh, and it is to be checked after it has sat for an extended period, like overnight.
Old Jan 3, 2007 | 10:51 AM
toolboxjunky
Question where is check valve
whre is the check valve located? how do you inspect it?
Old Jan 3, 2007 | 10:59 AM
cdiddy's Avatar
cdiddy
No problem here, just read a post where someone was checking his and it was low. Being a new diesel owner I wasn't sure about it.
