Burning out Glow Plugs 6.9
Hi,
I burned out a new set of beru's. The controller is not connected, I'm using a pushbutton. While working on a fuel problem I was doing a lot of cranking, but only using the plugs 10 to 15 sec at a time. I dont know if this burned out the plugs, or if it occured the last time the engine was running.
The plugs looked undamaged when I pulled them.
I'm not familiar with this motor or how the controller would normally cycle the plugs vs temp. (This truck is a junker I rescued)
How long should I heat the plugs on a cold motor?
How long do I need to wait before a second attempt?
How far advanced does the IP timing need to be before this will eat up the plugs. (I know its been messed with)
thanks,
Jason
thanks,
Jason
Originally Posted by Dogs-in-the-back
Hi,
thanks,
Jason
thanks,
Jason
These were from one of the big online stores and were in the sealed motorcraft bags. I tested them before installing and they were ok. I'm pretty sure burning out was a result of me on the button too long or the IP timing.
Incorrect IP timing wouldn't cause them to burn out - but powering them too long with a manual pushbutton will.
