Oil Smell
Old Jan 2, 2007 | 06:33 PM
Vrybusy's Avatar
Vrybusy
Oil Smell
Noticed the smell of burning oil yesterday and this morning on my 05 6.0 PSD (29Kmi). Seems like the truck has had some sort of leak for a while. The bottom of the Trans has oil all over it. Looks like it is coming down from the middle of the motor - Head area?? I really cant tell exactly where its coming from. Seems like the smell has temporarily gone away but it looks like I have to take it in and get it looked at. Has anyone experienced this? Or does anyone have any idea what it might be. Thanks for any and all help!
Old Jan 2, 2007 | 11:10 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Dealer can add dye to the oil and re-check in a few hundred miles... unless a visible leak is detected right from the start. Some of the wiring harness/sensors can leak as can excess assembly lube in the rear-main seal.
Yes, others have reported... so take to dealer and if under warrenty they will check it out... there are TSB's for them to reference to detect and fix.
Old Jan 3, 2007 | 06:44 PM
Vrybusy's Avatar
Vrybusy
Beachbum, Thanks! I think they tried the dye a while ago and didnt come up with anything - at least thats what the tech said that I was dealing with. Will have a different tech looking at it this time. How can a wiring harness "leak"? Do they access an oil source somehow? I read in another thread about a glow plug wire that could be leaking. This is all new to me. Truck is under warranty so I hope to have it in within the next week or so.
Old Jan 3, 2007 | 07:14 PM
Beachbumcook
Got Diesel?
TRy this link for info... site is good, but this link is about oil leaks...
http://www.forddoctorsdts.com/photographs/index3.php
Old Jan 7, 2007 | 03:09 PM
MIKE1646's Avatar
MIKE1646
My 06 started to smell at 6800 miles, but only under hard work.
Old Jan 7, 2007 | 06:27 PM
Vrybusy's Avatar
Vrybusy
MIKE1646, did you ever take it in to be fixed?? If so, what was the cause/origin of the leak?
Old Jan 7, 2007 | 06:56 PM
WishIhada7.3's Avatar
WishIhada7.3
i always have a drop of some sort of oil hanging from the bottom of my bellhousing.....doesnt look or smell like oil looks more like tranny fluid....
Old Jan 7, 2007 | 07:03 PM
kejsj30's Avatar
kejsj30
I just had an oil leak fixed.........
bad O-ring
leaking glow plug harness
pretty minor fixes, dealer had the truck for 3 days.
