Engine Trouble!
Old Jan 9, 2007 | 09:03 PM
  #46
Dave7.3's Avatar
Dave7.3
Well, an update on the truck guys:
Tonight I got home at abour 4pm and decided I would give the truck a shot. It hasn't been ran in about 2 weeks because I have been trying to troubleshoot it. About 39 degrees outside, pretty nice sunny day. First, I went and put in a good dose of Diesel Kleen in it since I had that ULSD in the tanks. I went to start it as you guys advised and about 4 seconds of cranking and she fired right up!! Runs like a champ and no choppy idle at all during start up, it was nice and smooth. Only 1 very small puff of smoke at startup.
I let it warm up to full operating temp and took the old girl for a drive. As I was pulling out of the driveway I noticed a light blue color smoke as I was heading up out of the old creek bed. I drove it a bit further and turned around to head home. On the way back, I put my foot down and yet again some light blue smoke. Even reving it and it smokes a light blue. I'm guessing that the CDR needs to be serviced. Do you guys think so or is there another problem?
Old Jan 9, 2007 | 11:40 PM
  #47
catfish101's Avatar
catfish101
Here we go. Now we are talking about off set keyways. Now we will get on changing buttons on Bigcams. Taking the stop screws out of 7FB 3406's, overdriving old 9speed front boxes and throwing on 13 speed back boxes with 24" rubber and 270 gears.
I am leaning towards leaving the cam timing alone but fooling with the lift a duration with modified rocker arms. Also solid lifters. There is alot of potential with the 6.9's.
Dave you may be burning a little bit of oil or you have one cylinder with a broken oil ring. I have seen that happened. The motor would still start good but the broken oil ring can cause a little oil burning. You may very well be right also. Does the exhaust have a strong acid type smell?
Old Jan 10, 2007 | 09:09 AM
  #48
Dave7.3's Avatar
Dave7.3
The exhaust has more of a burnt smell to it. I'm not sure if it is an oil ring or not seeing as it only puffs small amounts of blue smoke when under pressure...Any ideas?
Old Jan 10, 2007 | 09:49 AM
  #49
bc6.9's Avatar
bc6.9
Dave, I have the same sysmtons, personally I belive the oil is either comming thru the valves or rings [what else is there ] but the truck runs great other than 4700 EGT's @ 2,000 RPM empty
Old Jan 10, 2007 | 01:04 PM
  #50
Dave7.3's Avatar
Dave7.3
Do you think that this may be caused by the valve stem seals that I had done a few weeks ago? I'll have to clean my CDR when I get home tonight but that is the only other thing I can think of...
Old Jan 10, 2007 | 06:32 PM
  #51
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
One thing to remember by adding the diesel clean it CLEANS everything out and it goes out the exhaust. It could be the diesel clean smell you're getting. Run it for a while by driving it. Give the chemical a chance to work before doing other diag. Just go slow, one step at a time.
Old Jan 10, 2007 | 09:23 PM
  #52
Dave Sponaugle's Avatar
Dave Sponaugle
4700 degree EGT @ 2,000 RPM empty?
That is a problem.
Old Jan 10, 2007 | 09:46 PM
  #53
CheaperJeeper's Avatar
CheaperJeeper
That is a problem.
LOL! I think that is a typo. If the EGTs ever got to 4700 degrees there'd be no question about what the problem was.
It would be the molten puddle of pistons in the bottom of the oil pan. At least that would be the biggest problem....
Old Jan 10, 2007 | 10:21 PM
  #54
bc6.9's Avatar
bc6.9
OOOPS , yes it's a typo....one too many zeros! It's more like 470 EGT's
Old Jan 10, 2007 | 10:47 PM
  #55
dryrot42's Avatar
dryrot42
Thumbs up engine trouble
re the cam timeing rubarb, car craft mag did a piece about ten years ago and as I remember the big difference was less than ten hp in a roughly 400 horse motor. I believe advanceing 5 degrees lowered the hp curve 2-300 rpm and retarding raised it the same. It was done with an offset key. The point being a drag engine needs every little trick and with enough 5-10 horse add ons you might gain a couple 10ths in the quarter. The remark by Dave about cam lift was right on without flycuts in the pistons, but duration with porting could help considerably. Don't look to me for specs as I havn't a clue, that would go to a cam specialist. rockers with higher ratios give more lift and coincidently longer duration but we are back to the old piston again. Flow, flow, flow is what it's all about. Flow air, intake, pump[turbo, supercharger] ports in heads opened and matched[intake/exhaust] headers and open exhaust. Then the proper fuel mix at the right time = horsepower. No short cuts, just a bunch of steps as can be afforded towards the end game. PS, for those who read my last post the new shoulder is doing fine.
BillShaw89
Jul 13, 2014 07:24 PM
joe.d
Aug 14, 2011 06:56 PM
zswiss182
Nov 12, 2008 12:16 AM
01PowerStrokeF250
Jan 17, 2008 11:21 PM
Pocket
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Feb 14, 2006 07:39 PM
