Hissing
Old Jan 2, 2007 | 01:08 AM
cpettymore7777's Avatar
cpettymore7777
Hissing
95 f250 351. if i take my foot off the gas, or if i accell (going over 35 mph) i hear i hiss from the right side. if im in between it goes away. sounds like a vacume leak but i checked my vacume lines and they are good. any ideas?
Old Jan 2, 2007 | 01:46 AM
cpettymore7777
also the engine runs fine and has plenty of power. idel is good. it does not appear to be coming from the brake booster.
Old Jan 2, 2007 | 08:06 AM
95X15's Avatar
95X15
The air management system will release excess air from air pump at various conditions thru a muffler on right front inner fender well - has a hose thet goes down to bottom of inner skirt. This could be what you are hearing - I just never hear mine or have been able to pick out the exhausted air noise. You might check the condition of muffler and hose to be sure it is ok. Follow the rubber hose off the air pump to valves, then to muffler; I think it's plastic with metal end caps to the corrugated exhaust hose out of muffler.
With no adverse symptoms, I wouldn't worry about it.
