stalling at low rpm please help
hey i got a 97 f150 runs perfect and starts awesome well one problem it cuts off when i stop it will start write back up and idle fine but when i put it in gear and go as long as my foots on the gas its fine when i take it off it goes dead my check engine light said egr i replaced egr 70$ and iac $65 still same problem please help me
Welcome to FTE! You've put this in the wrong forum, but someone will be along shortly to correct it. As for your problem, I’d start with the IAC Valve, especially if it’s original.
Edit: I missed that you've replaced the IAC, well then i'd clean the maf sensor just for fun and maybe the fuel filter. Also, check your TPS.
