1950 F-1 rear axle swaps
Old 02-25-2001, 11:25 AM
cot's Avatar
cot
cot is offline
I am changing my drive train to a 302 w/ auto-o.d. from a 87 T Bird. what rear end will fit with minimum modification & still use a 5 lug pattern?My stock axle measures 60" hub /hub+ - 1/2".
What model/ year vehicles do i look for?
Old 02-26-2001, 05:57 PM
jwcnj45's Avatar
jwcnj45
jwcnj45 is offline
The rear from a 67-72 Ford pick up will fit right in your truck. The pinion angle will need to be adjusted by shimming at the spring pads. I modified a rear from an 87 Crown Vic for my 48. When I was looking for suitable rears for my truck I also found that a Nova rear from around 1970 would also be about the right width. With any rear swap you'll most likely have to fabricate a new driveshaft also.
Old 03-11-2001, 09:38 PM
cot's Avatar
cot
cot is offline
thanks for the response. i'm lighting the torches this week on the front suspension then i'll do the rear end. thanks again .
Old 03-12-2001, 06:32 AM
truckfarmer's Avatar
truckfarmer
truckfarmer is offline
if you are changing the front end, you may want to match the track width and bolt pattern to it. If you change the bolt pattern, finding a a car 9" rearend would be in order. Check 60-64 Ford Galaxy is 60". Also try 71-73 Mustangs and Cougars. Finding an 8" rearend in that range is easy.The 57-79 truck rearend will be about 1-1 1/2" wider than the stock rearend.
Old 03-12-2001, 11:41 AM
darkman's Avatar
darkman
darkman is offline
Deluxe06
11-07-2016 05:09 AM
dwarf
08-07-2008 09:05 PM
briggj
1999 to 2016 Super Duty
08-14-2007 10:34 AM
69crewcab
07-13-2004 08:37 PM
Quick Reply: 1950 F-1 rear axle swaps
