water pump
Old Jan 1, 2007 | 10:52 AM
Fire Rooster's Avatar
Fire Rooster
water pump
Any one know if the water pump is covered under warranty? 66000k miles on wifes excursion, came home from fire station today, she had already left to her station. I noticed about a quarter size puddle on driveway. smells and tastes like coolant. and in the right spot. Just assuming it is the water pump.. Hoping it is a warranty item.
Old Jan 1, 2007 | 11:11 AM
luvemhot's Avatar
luvemhot
Originally Posted by Fire Rooster
smells and tastes like coolant. .
that is an old breed fireman,
Keith
Old Jan 1, 2007 | 11:28 AM
Uzumati's Avatar
Uzumati
It shold be rooster, check under the pump pulley and see if the weep hole is leaking. Another place for a leak to spout is the gasket on the lower hose extension.
BTW: from an old school smoke-eater we have all done that more than once but after a spill a few years ago I added "If it glows dont taste it"
Old Jan 1, 2007 | 12:03 PM
Fire Rooster
I know shouldn't taste it. Figured it was either coolant or, home brew Biodiesel. BD harmless, Coolant safe to taste if you wear a turnout coat right?
Alway nice o see a few more smoke eaters hangin around!!
Old Jan 1, 2007 | 12:39 PM
luvemhot's Avatar
luvemhot
fire rooster
I liked your hpop cover i contacted heatstrocked to see if he would make me one, now i just need to decide when i want to but it
just make sure the coat is zipped and the velcro closed all the way and you should be ok
Keith
Old Jan 4, 2007 | 03:39 PM
Fire Rooster
OK water pump is not leaking. It is the gasket between the water pump and where the lower radiator hose connects.
Two questions, one is that gasket truly a gasket or is it the bead gasket that comes in a tube?
Second, I am gonna try some alummaseal type stuff first. Where do I put it in? in the overflow tank or remove the upper radiator hose and pour it in there?
Old Jan 4, 2007 | 06:39 PM
Uzumati's Avatar
Uzumati
The lower extension has an oring in it for the seal. Permatex "The Right Stuff" works wonders.
Old Jan 4, 2007 | 07:33 PM
Fire Rooster
Can you buy a new oring? and will this Bars Leak work? Says it also lubes water pump etc. Conditioned for diesel coolants blah blah blah
Old Jan 4, 2007 | 07:44 PM
Uzumati's Avatar
Uzumati
After looking at the first filter i replaced and seeing the silicate built up when I swapped the water pump I dont like to put anything in there except coolant. I think the oring just comes with the lower extension assembly, try this link http://www.thedwilsons.com/powerstro...t_Numbers.html it may have one.
Old Jan 4, 2007 | 07:52 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
DO not use the bars leaks, it is crap! It may lube up whatver it does,but it also coats the walls of the entire cooling system, including the water jackets, where the cool water is needed. The layer of this junk on the walls decreases heat transfer and greatly decreases the efficiency of the cooling system. That said, The Right Stuff does work well, i used that on a customer's truck when i removed his lower radiator hose elbow for the oil cooler job.
Old Jan 4, 2007 | 08:04 PM
Fire Rooster
IS the "right stuff" is it a new gasket I know pematex makes all kinds of gasket stuff.
Old Jan 4, 2007 | 08:10 PM
PowerstrokeJunkie
Yep, its a "make-a-gasket" you can use on just about anything. I usually let it sit for a minute or two to get tackyyyy. I had to use it on my compressor housing when i rebuilt it, and you should have seen me prying it off the turbo when i went to install the ATS housing. Boy was that sucker tight. I could have saved 5 bolts for something else
powrstrkn''s Avatar
powrstrkn'
"The Right Stuff" is actually a Permatex product, the auto parts store should carry it.
Old Jan 4, 2007 | 08:13 PM
Uzumati's Avatar
Uzumati
its kinda like a spray on gel gasket maker. it looks like a cheeze wiz can
Old Jan 4, 2007 | 08:20 PM
Fire Rooster
still gotta take the lower assembly apart to do it huh? Damn, short on time but Ican do it.
