Is there anything to watch out for in an '03 Explorer XLT with the V6? My wife and I need another family vehicle due to the growing family and want a SUV.
Some of the early Gen III V6s had problems (noise) with the cam chain tensioner, and some had the wrong formula tranny fluid installed at the factory (your dealer can run the VIN to see if the tranny additive was needed and put in).
If that '03 has the towing package, there have been some issues (noise) with the clutch packs in the LS rear ends that require replacement.
Check the plastic trim panel under the liftgate window; it's prone to cracking.
45k, no real problems. Noisy rear end replaced under warranty, still unclear if it ever would have become anything more than a noise. It stll has some whine at 60 mph or so but better than before. Fine ride otherwise.
i just bought and 03 xlt v-8 about a month ago and really like it so far - from what i read here i guess i should check and see if rearend has been replaced
Thanks for the input guys, gonna look it over a little better tomorrow and see what's up and see if I can get a carfax report on it to see what it has been thru.
It does have the 1.25" hitch so that isn't considered a towing package right? I would think that the towing package would only be the 2". What is the tow rating on the 1.25" hitch? Is it enough to haul a 4 place aluminum snowmobile trailer?
