Sponsored by: Real Truck
overhead console question
Old Dec 31, 2006 | 06:27 PM
mudmaker's Avatar
mudmaker
I am assuming there is 12v available inside the console. I need to know how to remove the console. I assume it pops off, but I dont want to break anything.
It is on an 02 F350 Lariat
Old Dec 31, 2006 | 06:44 PM
ReAX's Avatar
ReAX
I had mine off a few months ago to put some insulation on the roof. I believe there are two bolts and some clips.
Old Dec 31, 2006 | 08:41 PM
PHWLEE's Avatar
PHWLEE
I don't recall offhand if there are those two screws, but I know you just kind of pull down on it and it will come off. It will make a horrible noise, which is the metal snap in clips against the metal body, but it's not a problem.
Old Feb 19, 2007 | 07:51 PM
MAH's Avatar
MAH
How do you remove the overhead console in an F250/350 2006 or 2007 carryover?
I can easily remove the cover (that is the part that matches the interior colors). That has four clips. You pull on the cover, the clips make an awful noise and the cover comes free. Not so easy to put it back, but eventually I will get all four clips to align.
However under this is black plastic case. I will need to remove that for modifications.
How is this black casing removed? If there are screws, where exactly are they. I’ve had the cover off for a week and I’ve made no progress removing the black interior case despite several attempts
i eat hybrids
Aug 13, 2012 05:39 PM
sithot
2009 - 2014 F150
20
Nov 9, 2011 06:56 AM
gui88ford
2004 - 2008 F150
Dec 31, 2008 11:50 AM
rcdanbo
1997 - 2003 F150
Apr 2, 2006 01:17 PM
