Excursion Rear Leaf Spring Questions
Old Dec 31, 2006 | 05:02 PM
KHNewman's Avatar
KHNewman
Hi everyone,
I'm new to the forum and have been doing substantial reading on the X leaf springs. I have a few questions and was hoping some of the experienced folk here could help me out because my suspension already has some mods.
I have a 2002 X and I currently have a tough country 2" lift kit installed (essentially a levelling kit that adds extra leafs to your front and rear springs) and includes the longer u-bolts etc. I have Bilstein 5150 shocks that are sized to the current suspension height. I like the current height because it let's me run 33 x 12.5" Super Swamper TrXus STS 10ply tires. I am considering changing out the rear leaf spring to the "B" Code F-250 springs so many people have recomended. The reason for the change is that I recently had a custom made receiver hitch installed and it is substantially heavier then the stock hitch and I feel like my suspension is now sitting slightly *** heavy.
Here is my questions:
If it put in stock "B" code F250 springs and remove the factory springs AND the tough country additional leafs does anyone know if I will come out at or above my current height of +2" over stock?
I absolutely want to make sure I come out at least level or sligtly higher in the rear. I regulary tow a 14' Cross Country Equipment Trailer that has a 10K GVWR and is normally around 4K to 6K pounds. I don't like that when I hook up the trailer that I tend to sit *** heavy.
I don't use weight distribution because the tow distances are short and I am hooking and unhooking the trailer frequently. I had a heavy duty custom hitch installed because some of the rental places gave me a hassle that the hitch says 5K and if I am renting a bobcat that with the trailer is almost 10K. I LOVE the custom hitch because it is REALLY havey duty and they built it to include a larger step so I can easily get to my roof rack.
When I change the leaf springs I will add a Hellwig rear sway bar and was considering the RAS but I might consider rear air to adjust the ride to level depending on the load I am carrying which could be 2K with the empty trailer to 10K for a bobcat.
Old Dec 31, 2006 | 06:07 PM
KHNewman's Avatar
KHNewman
Front axle weights used are 4080, & D code springs for the PSD and 3680, & C code springs for the V-10
Application---Code---Capacity-----Rate----Travel --------- V-10 ----- PSD
--------------------------------- /spring---to Max Cap ----height ----height
--------------------------------------------------------- change --- change
Exc V8 ------- B ----- 4100 ----- 330 ----- 5.02 ---------- -0.25 --- -0.66
Exc V10 ------ C ----- 4300 ----- 350 ----- 5.01 ----------- 0.00 --- -0.37
Exc PSD ------ D ----- 4700 ----- 380 ----- 5.14 ---------- +0.33 ---- 0.00
F250/350 All springs are computer selected
Also the use of a rear sway bar and what size it is package dependant
SD-250/350--- S -----4000 ----- 370 ------ 4.34 --------- +1.22 --- +0.88
-------------- T ----- 4400 ----- 390 ------ 4.63 --------- +1.42 --- +1.11
-------------- U ----- 4800 ----- 410 ------ 4.89 --------- +1.60 --- +1.32
-------------- V ----- 5200 ----- 430 ------ 5.13 --------- +1.77 --- +1.50
F450 -------- W ----- 5600 ----- 450 ------ 5.34 ---------- +2.77 --- +2.52
F550 &350/ DRW with Snow Plow prep Package
-------------- X----- 6000 ----- 470 ------ 5.54 ----------- +2.90 --- +2.68
Old Dec 31, 2006 | 06:12 PM
KHNewman's Avatar
KHNewman
Am I reading the chart I posted above correctly? If I am reading this right it says that the B Code springs have less capacity then the C Code springs and that it lowers the X in the back?
Old Dec 31, 2006 | 08:50 PM
200Proof's Avatar
200Proof
The chart posted is for FRONT springs, rear B Code springs will raise the rear end about 1/2" at most. I have them on my X and only gained about 1/4", but the rear end doesn't squat when I hook up my trailer that weighs about 8K
Old Dec 31, 2006 | 09:32 PM
KHNewman's Avatar
KHNewman
Thanks...that is what I wanted to hear...so I can change my stock springs out and leave the add a leaf and only pickup 1/2" which I need to level me out anyway!
tdlpps
Sep 30, 2021 06:48 AM
268Fords
Sep 16, 2016 07:21 AM
Greg5OH
Jul 2, 2015 04:08 PM
Sous
20
May 11, 2015 07:37 AM
sinister73
Sep 24, 2005 11:42 AM
