fuel shut off solenoid connections
Received 3,127 Likes
on
making progress...
OK...disconnected the front one and it shut off the engine.
So...the back one is cold idle advance...this advances injection timing at cold temps?
And the solenoid on the right which acts against the throttle linkage simply increases idle speed at cold temps?
thanks all,
(trying to learn what makes this baby run)
thanks all,
on
Can any of those be used as a quick "idle up" device like when using an ancillary device?
I know when I needed to idle up any of my gasoline vehicles temporarily, I'd stick +12 volts to the A/C solenoid or the "Bypass Air Control Valve" or something of the sort. They're simply air passages that bypass the throttle plate.
There is no such thing on a diesel which confuses me as to how you regulate it's speed.
[QUOTE=Pele]Can any of those be used as a quick "idle up" device like when using an ancillary device?
You would have to buypass the thermal switch located on the front section of the passanger side head. It is closed providing power to the advance soliniod and the throttle kick up soiliniod until the temp reaches 112F.
