AOD Slipping?
Old Dec 31, 2006 | 03:01 PM
STACK86's Avatar
STACK86
AOD Slipping?
I have a 1986 F-150 with 302 and AOD. The transmission shifts fine but seems to have some slipping under load in OD. Slight shudder and almost feels like a high speed miss except it only happens in OD. There is no indication of any slippage or miss like symptom in 3rd. Any ideas?
Thanks
Old Dec 31, 2006 | 09:07 PM
stuart1's Avatar
stuart1
Even a slight stumble from the engine will be magnified with an AOD transmission.
Old Jan 2, 2007 | 06:55 AM
LEVEL10's Avatar
LEVEL10
Thanks
Hello,
Give us a call, we can help you diagnose your transmission problems, and supply you with the correct parts to fix the problem.
Mike
Level 10 Tech
973-827-1000
http://www.levelten.com/
Old Jan 2, 2007 | 07:08 AM
LEVEL10's Avatar
LEVEL10
Thanks
Hello,
Please give us a call. We can help you diagnose you trans problems, and supply you with the necessary parts to fix it.
Mike
Level 10 Tech
973-827-1000
Old Jan 2, 2007 | 12:49 PM
mudgepondexpress's Avatar
mudgepondexpress
Sounds like the OD band is worn out. A common problem on the early AODs for they use a narrow band and a small apply piston. This is why the owners manual tells you not to tow in OD. The later AOD's (AODE and 4R70W) can tow in overdrive due to an increase in band area.
You can retrofit the later band into the early tranny...problem being you must disassemble the tranny partially to do it.
Kenny
dirt_bag
Aug 5, 2015 10:46 AM
nastruk95
Jul 30, 2015 11:25 AM
Bluet1k
Apr 25, 2015 09:08 PM
pfeifer5
1997 - 2003 F150
Dec 28, 2014 04:09 PM
88bronc
Jan 13, 2003 09:33 PM
