Hi Everyone! Hope you all have had a good Holiday Season!
I have a 2000 F250 SD that is getting to the point of needing a new seat cushion. the past owner sat with his feet out the door on the running boards a lot (while he was parked) so the foam is broken down on the door side.
Anyone out there know of some after market place that I could order replacement foam?
Thanks in advance for your help!!
Ford has replacement foams, infact I have a new foam and leather sitting in my closet for a rainy day. You will not find many if any aftermarket stock replacement foams. If you absolutely will not go back to ford, your best option is to have an upholstry shop custom build one.
