Fuel Tank Relocation
Old Feb 27, 2001 | 10:03 AM
newjob001's Avatar
newjob001
Hi. I have a 52 Ford F2 which I am modifying. I would like to relocate the gas tank and would like recommendations on what tank works best and where I can get one. Any help would be appreciated.
Old Feb 27, 2001 | 06:49 PM
trouble's Avatar
trouble
In what area would you like to move your tank to ??
Old Feb 27, 2001 | 06:53 PM
newjob001's Avatar
newjob001
I would like to relocate it under the bed. Either way, it would help to get it out from behind the rear seat.
Old Feb 28, 2001 | 09:14 AM
dennis the medic's Avatar
dennis the medic
Hey I don't know how to relocate the tank But if you don't mind I'm trying to find brake parts for my 48 f2 I'm missing the rear brakes and all the hardware.If your ditching the rear end maybe we could work something out good luck Dennis
Old Feb 28, 2001 | 10:31 AM
newjob001's Avatar
newjob001
I have cut the rear out and other parts too, and I am looking to get rid of stuff. Give me your e-mail address and we will hook up. Quick list is the V8 Motor, Trans, rear and front end.
Old Feb 28, 2001 | 01:49 PM
gdub's Avatar
gdub
I put an 84 Isuzu trooper tank in the rear my 51 F-1. There was an article about this in either Classic Trucks or Custom Classic trucks a few years ago. It is an easy install and only cost $65 from a junkyard.
Old Mar 1, 2001 | 07:51 PM
jniolon's Avatar
jniolon
old and in the way
I used a mid 60's mustang tank in my '53... easy to find
fits perfect... filler in the bed... see my article on the FTE Tech Articles Page
hope this helps.
john niolon
Old Mar 5, 2001 | 12:00 PM
copeina's Avatar
copeina
I used a 1985 Bronco II tank and mounted it at the rear of the frame. Not too much difficulty involved.
/Kris Taylor
Winnipeg, Manitoba, Canada
1950 F47 (almost ready to roll!)
Old Mar 6, 2001 | 06:54 PM
disvnvet's Avatar
disvnvet
With all these fuel tank changeouts, are all of you having to modify the frame or are you leaving the rear structural member in place. The Musting and bronco??
Old Mar 7, 2001 | 12:00 AM
tkbowman's Avatar
tkbowman
[font size="1" color="#FF0000"]LAST EDITED ON 07-Mar-01 AT 01:02 AM (EST)[/font][p]Where did you locate the filler neck on the Bronco tank?
Tim in Burien
Old Mar 27, 2001 | 05:33 PM
fords2952's Avatar
fords2952
[font size="1" color="#FF0000"]LAST EDITED ON 27-Mar-01 AT 06:35 PM (EST)[/font][p]I have a 52 that has a 20 gallon tank out of,I believe,a Fairmount or Granada,78/79?? I bought this truck with this tank already in it and I think that's what he told me. The tank unit is on the lower left side of the tank. The filler is inside the bed! this tank gives a good driving range on long trips,around 300 to 350 miles!! Almost forgot,the tank is at the rear,between the frame rails!
Old Apr 2, 2001 | 01:43 AM
darkman's Avatar
darkman
On the Granada/Fairmont tank does it have a flange around it like the Mustang? How does your gauge work? Is it original?
Thanks Charles
Old Apr 2, 2001 | 08:08 AM
newjob001's Avatar
newjob001
Thanks for all the suggestions and information. This past weekend I completed the installation using a Mid-60's Mustang tank in the truck. I used the following for instructions:
https://www.ford-trucks.com/articles/oct2000/mustangtank.html
It worked like a dream. Only thing the article didn't mention was that I needed to grind a hair off the frame rails to make it fit. Other than that, it was easy.
Old Apr 3, 2001 | 03:39 PM
fords2952's Avatar
fords2952
I used the original sender and pieces from an 87 T-bird sender to get the correct ohms to match the 87 Ranger cluster I put in.The tank unit is held in by a twist in metal ring. I am going to change the gauges to the new Dolphin speedo and 4 in 1 41/2 set that fits in the orignal dash holes,so I will probably have to change the sender again!
Old Apr 4, 2001 | 01:32 PM
copeina's Avatar
copeina
On the bronco, I am looking at either in the bed (drivers side) or frenching it into the box side.
I also had to add a crossmember at the front of the tank and fabricate some straps. All told about 8 hours involved.
/Kris
