Major miss?
Old Dec 30, 2006 | 05:05 PM
goatdriver's Avatar
goatdriver
Major miss?
2004 F150 Screw Lariat. All of a sudden, it has this terrible miss. The whole truck is vibrating and barely running. No check engine light. Is it possible I got bad gas? Problem is, I did not recently refill. I am at a quarter tank?
Old Dec 30, 2006 | 06:21 PM
wildcard30's Avatar
wildcard30
Have you ever changed the fuel filter?? How many miles on your truck?
Old Dec 30, 2006 | 06:26 PM
96f150's Avatar
96f150
Sounds like an injector let go on you. how does the exhaust smell? Can you smell raw fuel?
Old Jan 1, 2007 | 07:46 AM
goatdriver's Avatar
goatdriver
It has been confirmed that I have water in the gas. I have approximately an 1/8th of a tank left. I will call the dealer in the morning to see if they can pump it out, or if I can add an additive to burn it out.
Old Jan 1, 2007 | 08:20 AM
Big-Red-Lariat's Avatar
Big-Red-Lariat
Keep it above 1/4 full during winter, and use a bottle of gasline antifreeze (or cup-full of methyl hydrate) at each fill up December to March. I had this problem after an oil change in a heated garage with low fuel, and then when you drive back into the cold, condensation in the tank waters down the gas...easier to just keep the tank close to fulll most of the time in Winter. Good luck!
1bad04
Dec 22, 2010 09:33 PM
97powersmoke
Nov 3, 2008 10:45 AM
n8sv10
Modular V10 (6.8l)
Sep 26, 2008 02:01 PM
95_Ford XL
Mar 20, 2003 02:20 PM
