Sponsored by: Real Truck
limited slip
Old Dec 31, 2006 | 09:13 AM
thedaddycat's Avatar
thedaddycat
I was backing up over the curb the other day, left tire spun but right did nothing. I guess the first thing is the fluid change, which I am going to do anyhow for front, rear and transfer case. I also looked online at several products and guess I need to dig a little deeper to get a better understanding of how things work. This is my first four wheel drive so I have no experience to go by...
If the fluid change doesn't give me the results I'm looking for is installing a Detroit locker or Trutrack something best left to a shop, seeing as I have no dial indicator, etc. About the only precision measuring device I have is a digital caliper and I've never messed with gears so I don't know what to look out for.
Old Dec 31, 2006 | 12:44 PM
Ronin007's Avatar
Ronin007
bronco521 - according to Detroit Locker's website the Truetrac will work in all SD's from 1999 and up. You could probably shoot them an email and check for sure.
thedaddycat - installing one is not difficult if you have the equipment. I don't so I had mine done at a buddies shop by a guy who has done lockers and gears tons of times. Do the fluid change first as that my solve your problems. Several people on here have had good luck just doing that. Cheap fix if it works for you.
Old Dec 31, 2006 | 03:04 PM
bronco521's Avatar
bronco521
i don't know who it was on here but they said the 05 and up 350 rears were 37spline and the others were 35.could be bad info and i haven't checked any further into it until i'm ready to put one in.
Old Dec 31, 2006 | 03:55 PM
daveshan's Avatar
daveshan
Originally Posted by pottymouth2
Jack up one side and try to drive off. If you can't it is an open differential.
Or a stock Ford LS. I tried this after my '06 wouldn't get up my driveway if one side was wet. Didn't budge an inch. There may be a quality control issue, some may drive off the jack but mine sure won't. Took it to the dealer and they told me it was fine. Any time I am in slippery stuff I just use 4wd. Once things get a bit less snowy I'll be trying the fluid change with less friction modifier.
Old Dec 31, 2006 | 04:03 PM
BFR250SD's Avatar
BFR250SD
That is correct. The 250's have a 35 spline, 1.5" dia axle shaft. The 350's have a 37 spline, 1.57" dia axle shaft. I don't think anyone has an aftermarket LS for the 05+ 350's yet.
Old Dec 31, 2006 | 04:14 PM
bronco521's Avatar
bronco521
thank you.hopefully they will come out with a true trac before next winter.
Old Dec 31, 2006 | 04:17 PM
BFR250SD's Avatar
BFR250SD
I skipped all that......just went straight to ARB's front and rear. Loved 'em.
The only thing you need the watch on the Truetrac's is that they don't recommend them for anything bigger than 33" tires. They are a nice setup though.
Old Dec 31, 2006 | 06:12 PM
bronco521's Avatar
bronco521
i won't put anything bigger than that on it.
Old Dec 31, 2006 | 08:20 PM
thedaddycat
Well, the fluid change is done on front and rear so we'll have to see what happens when we get some snow. I couldn't find 80W90 full synthetic for the front differential but did manage to get Mobil1 75W90 full synthetic, I doubt it will make much if any difference being 5 winter weight lower. I was suprised at how much it took to fill the differentials, 3 quarts front and almost 4 quarts rear. I even measured the drained fluid to make sure I wasn't screwing it up somehow, looked to be just a tad more than came out. I'll drive around tomorrow and then pull the fill plugs to see how much if any excess there is.
While at Advance Auto I also saw a Lucas Oil product called "Pure Synthetic" synthetic oil stabilizer. Does anyone have any experience or feedback on this stuff? Lucas seems to have a fairly decent rep from what I've read.
Old Jan 1, 2007 | 12:06 AM
BFR250SD's Avatar
BFR250SD
Do not use that stuff in your diff. Does more harm than good, especially mixed with synthetics. Makes the oil very thick and aerates it at speed. Stick to oil and it's all good.
Old Jan 1, 2007 | 07:23 AM
RBC-01's Avatar
RBC-01
with the Ford LS not hooking up just run a little brake for a couple of wheel turns than release..seems to allow the LS to hook-up.
seems to help untill you cut down on the modifiers. The 05's and up should have factory fills of synthetics which should elimenate any modifiers unless you have chatterring..
cheers
Old Jan 1, 2007 | 07:48 AM
BFR250SD's Avatar
BFR250SD
All trucks with the LS have synthetc fluid. The friction modifier is still required,unless you are using an aftermarket fluid that already has it in it.
Brakes help, but the problem is the Ford OEM LS breaks free at a rediculously low torque load, something like 100 - 125 lb/ft. That's if it's working correctly.
Never been a fan of the clutch type "limited slips", you'd be better off calling them "limited traction"
Old Jan 1, 2007 | 07:57 AM
  #28
bronco521's Avatar
bronco521
the factory l/s opens up at 25lb/ft.i believe they did this because of liability.they don't want blue haired gramma loopin her duty the first time there is snow or rain.then combine this with continentals and yer better off with a subaru brat in the snow.
Old Jan 1, 2007 | 08:21 AM
  #29
BFR250SD's Avatar
BFR250SD
Basically, the only thing the factory LS is good for is being used on surfaces that offer remotely the same amount of traction between both wheels, i.e. wet pavement.
But,for a $300 option, you could always just put a rubber band around the spider gears and get the same effect.
Best thing to do is like stated before, change the fluid, add 2 oz at a time while doing a series of sharp turns until you just barely hear the clutch pack chattering. Just keep in mind, the Motorcraft Synthetic gear oil is about $17 a qt and you need just under 4 to refill the dif.
Old Jan 1, 2007 | 08:31 AM
  #30
900rr's Avatar
900rr
does the motorcraft synthetic oil have to be used in my manual it states i think 75w145 gear oil and says nothing about any modifier sor the rear. before the cover on mine was changed it seemed ok not great but ok after the change in fluid it does not lock up as well. so i guess my question would be what fluid do you use manual spec or the forums thanks for any help
