1988 F-150 6cyl 300 v6 2 years ago truck stopped. repair was fule pump in rear tank. Since then it stalls every 3 to 5 months so they put a in line rail fule pump. Still 3 to 5 months i go thru the same thing. 2 weeks ago it stalled i just walked home. 2 days later i went back and started. It stopped 3 days later so i put a new rail pump on. It would not start. Then i put the old one back on and it started. Every day or 2 its stops. Got under the hood and pulled relay pulls apart and back together, this made it work. It if stops now i bang the relays a off it goes. Does anyone have a clue what i can do?
You can click on the link that Big put in his message.
Or you can click on the forums tab at the upper left. Clicking on it will display all of the tech forums and you can then browse over them and select the one you want.
