My fuel pump is leaking from the weep hole and needs to be replaced.
I am going to be doing injectors soon. (beans stage 1 or 2's)
Is there a upgrade for the original carter pump? Should I upgrade anything else to run these injectors?
Thanks for any help.
95, 5spd, 4x4, 198,000 mi.
3.5in down pipe
5in downpipe back
gauges
You are OK with a stock pump for those injectors. I would shim the FPR (fuel pressure regulator). All you need is a 3/16 Ball bearing. Be sure to check your fuel pressure afterwards to be sure it's not too high. The fuel pressure gage will bounce like crazy but you will be aqble to average the bounce. No more than ~80 lbs. Search this forum for FPR shim and fuel pump replacement for a lot of good tips. If you have any questions or trouble come back here and get some help. Lots of good, knowlegeable guys here.
