mustang intake
Old Dec 28, 2006 | 08:08 PM
cuztom79's Avatar
cuztom79
mustang intake
89 f-150 302, thinking about maf conversion, will the upper and lower stock mustang intake work well in a truck,and where would u get a bracket for the tv cable on the trans
Old Dec 29, 2006 | 09:42 AM
gustang818's Avatar
gustang818
The Mustang intake will bolt on but you might do better using an Explorer intake. It moves the torque band lower which will get the truck rolling better.
Lokar makes a tv cable kit for an aod (kd-2aodht). http://www.lokar.com/interior_pages/tc_kd.htm
Old Dec 29, 2006 | 12:55 PM
Conanski's Avatar
Conanski
The mustang intake has much smaller runners than the truck in terms of cross section and length, and while this may sound like a bad thing, I suspect you may actually see an increase in power production across the board because of higher intake velocities. It certainly should produce more upper rpm horsepower, but the cam will ultimately restrict it to something less than the HO motor... unless you change that too. Mustangs were available with the AOD tranny so the cable mounting plate should be available in scrap yards and such. A plate from a Crown Vic or TBird should also work.
Old Dec 29, 2006 | 03:33 PM
cuztom79's Avatar
cuztom79
thanks guys,that really helps. if i do it, im going to do it all, intake, cam, headers.the only thing, where do u put the air intake tube, it will be on the pass. side instead of drivers now.
Old Dec 29, 2006 | 04:12 PM
EPNCSU2006's Avatar
EPNCSU2006
The ports are symmetric, so you can mount the upper manifold turned 180° from the normal car orientation to get the throttle on the drivers side.
Old Dec 30, 2006 | 11:45 AM
cuztom79's Avatar
cuztom79
thanks, im a *******! sometimes its the easy stuff u look over!
Old Dec 30, 2006 | 12:16 PM
EPNCSU2006's Avatar
EPNCSU2006
Don't feel bad, you certainly aren't the only one who didn't know that. The lightning trucks use the GT40 style intake, similar to the explorer one and it faces the driver side.
Old Dec 30, 2006 | 12:24 PM
jk89cat's Avatar
jk89cat
[QUOTE=gustang818]The Mustang intake will bolt on but you might do better using an Explorer intake. It moves the torque band lower which will get the truck rolling better.
Lokar makes a tv cable kit for an aod (kd-2aodht). http://www.lokar.com/interior_pages/tc_kd.htm[/QUOTE]
bingo, dont waste your timewith a stock ho intake. the explorer is a much better get up and if you use a stang or mn12 harness and pcm your truck will run much much better .
Old Dec 30, 2006 | 02:39 PM
Ford_Truck_Man_07's Avatar
Ford_Truck_Man_07
Question
Originally Posted by gustang818
The Mustang intake will bolt on...
Then what would keep you from bolting on a aftermarket Fox Body intake like this bad boy...
http://www.jegs.com/webapp/wcs/store...20331_-1_11935
Other than the price I guess...
Old Dec 30, 2006 | 03:07 PM
Conanski's Avatar
Conanski
The Explorer and Cobra intakes use cast version of the GT-40 tubular upper. The lower portion of all 3 is nearly identical, as is the runner cross section and length.
Old Dec 30, 2006 | 03:16 PM
Ford_Truck_Man_07
So the price is the only thing keepin a guy from doin it? Would the cobra part produce the same ammount of power since they are nearly identical?
Old Dec 30, 2006 | 04:31 PM
jk89cat's Avatar
jk89cat
cobra, explorer = production gt 40
Old Dec 31, 2006 | 02:28 PM
cuztom79's Avatar
cuztom79
the gt-40 intake=the cobra, explorer ,right? what about a trick flow intake , i heard they produce a butt load of power as long as u have some head work done. or if u went the gt 40 route i bet u could get it from a junk explorer for a lot cheaper than new. is there a diffenece in production and aftermarket gt-40, thanks for all your help.
Old Dec 31, 2006 | 05:56 PM
jk89cat's Avatar
jk89cat
yes the upper s are different for different sensors and such , i am persoanlly usign a 94-95 cobra on my 89 cougar with a 347 , trick flow is a good option too , you can usually pull an intake used for 100 or so
Old Jan 1, 2007 | 09:21 AM
currituckF150's Avatar
currituckF150
What is an "explorer" intake & how do you identify one? What vehicles came with it?(hope that is not a stupid question)
