Antfreeze
Old Dec 28, 2006 | 06:24 PM
busdriver47's Avatar
busdriver47
Antfreeze
Can you use any other than the ford gold.
Old Dec 28, 2006 | 07:11 PM
mrxlh's Avatar
mrxlh
Only if you flush the entire system out several times. Matt uses some of the expensive stuff, evans I think, but the PSD doesn't need it in stock or slightly modified trim, the gold is plenty sufficient. Is price your main concern? The gold is probably the best ever offered by a manufacturer. It needs no additives for the waterpump, and no one here has ever had an issue with a 6.0 and the coolant, other than it leaking when a cooler leaks or head gaskets start leaking.
