Sponsored by: Real Truck
Suspension question
Old Dec 28, 2006 | 06:00 PM
Wingedpig's Avatar
Wingedpig
Suspension question
I have a 2007 F-250 PSD Lariat SC FX4 short bed with the 9800 lb. GVWR. When I looked under the rear to check the blocks under the springs it looks like I have the four inch blocks like one would find on an F-350, instead of the two inch blocks.
Am I correct in assuming that this is due to the 9800 lb. rating? I was thinking of changing out the blocks to the larger F-350 ones, but now it looks like they are already there.
Am I seeing this right or am I measuring them incorrectly?
Old Dec 28, 2006 | 06:01 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
did you actually put a tape on it???
make sure your not measuring the spring perch as well
Old Dec 28, 2006 | 06:04 PM
Wingedpig's Avatar
Wingedpig
Not sure about the spring perch. Guess I'll have to go measure it again.
Thanks.
Old Dec 28, 2006 | 08:26 PM
DD1684's Avatar
DD1684
I highly doubt that it has different blocks. If it does then they're probably still smaller than those found on an F-350.
