getting a c6 off
Old Dec 28, 2006 | 05:15 PM
79-400-POWER's Avatar
79-400-POWER
getting a c6 off
how does a c6 come off a 351m?
and also how does a np205 come off the c6?
Old Dec 28, 2006 | 07:49 PM
stuart1's Avatar
stuart1
Undo the bolts.
Old Dec 28, 2006 | 09:28 PM
79-400-POWER
oh! is that all?! now why did i not think of that!
Old Dec 28, 2006 | 09:53 PM
bronco521's Avatar
bronco521
well,it's that simple.what question do you have?it's pretty straight forward.
Old Dec 28, 2006 | 09:58 PM
79-400-POWER
well i have them out of the truck, and all the bolts out, but they wont come apart.
Old Dec 28, 2006 | 10:10 PM
bronco521's Avatar
bronco521
the tranny to the t-case?sometimes the gasket makes it act like they are welded together.one side,tranny to adapter or adapter to tcase,has a dowell to clock things correctly.the last time i had mine out had ,the adapter was stuck to tranny.took bolts out of t-case side and whacked it with mallet a few times and it came apart.the gasket kinda stuck to both sides.it'll come apart,just need to get ornery with it.
make sure ALL the bolts are out before prying/hitting/swearing.
Old Dec 28, 2006 | 11:30 PM
plowpusher's Avatar
plowpusher
for the tranny you have six bolts from the bell housing to engine bloc the two starter bolts the four nuts that hold the coverter to the ring gear/flexplate (these are under the cover at the bottom front of the tranny)linkages cooling lines vacum line, and cros member ,tranfercase the bolts to adapter,linkage, speedo cable and driveshafts support the tranny put a jack under the transfercase you may have to "pop" it with a hammer or a prybar
Old Dec 29, 2006 | 04:42 PM
79-400-POWER
I had all the bolts out, I just did not want to start hitting and prying and there be somthing i did not know abot still holding it togeather.
thanks for your help.
