Tow mirror mod...
Old Dec 28, 2006 | 10:57 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Mine are on the way, too!!! Ryan, you tha man!
Old Dec 28, 2006 | 11:44 PM
F250_'s Avatar
F250_
OK guys... looks like we have the light thing figured out. Now for the "heat" option... I found a source!!
I tend to get really cranked up when presented with a challenge like this one, and you guys have inspired me to new limits. I do not yet have any cost information, but it is entirely possible to get a replacement mirror glass and install a new heating grid element as an upgrade. I'll have to rely on you guys for the wiring details for inserting this option into our vehicles, but I know that some of you are up for that challenge just as much as I was up for the portion I've dealt with.
Here's the link to one company that can provide both the glass and the heating element. http://www.burcoinc.com/Replacement_Mirrors/Sideview/Redi_Heat_Complete.htm
I'm going to check on the prices from Safelite tomorrow. Part numbers for the glass are #2316 (passenger side glass for the 02-F250 Trailer Tow style) and 2317 (driver's side). I'll post my findings.
Old Dec 28, 2006 | 11:50 PM
RAMPAGE_F350
If it works out then you can put it on a temporary switch until its cost effective to get the factory one on the door. My question is: Your in my neck of the woods, what do you want with heated mirrors? Mine never get frosted up unless there is a ton of humidity and even then its not that bad.
Old Dec 28, 2006 | 11:56 PM
F250_'s Avatar
F250_
I can't get either my truck or suburban in my garage, and it definitely gets cold enough and frosty enough here in Birmingham to take advantage of this feature (like this morning). I actually have two things helping me keep this effort on a shoe-string budget... cash flow and exactly what you alluded to - it's not a really critical thing here, but useful all the same.
Old Dec 29, 2006 | 12:02 AM
RAMPAGE_F350
Understandable and like you said peviously, presented with a challenge!
Old Dec 29, 2006 | 12:29 AM
empiretc's Avatar
empiretc
Not quite sure which you are talking about, but my truck did not have power mirrors. They were manual, non-telescopic, non-heated. I got the factory power-mirror switch from a local stealer for $20. I used a regular power switch out of an old power supply to control the heat. It was a lot of fun (aka PITA) running all the wires and hooking up the switch without a pigtail to it. BUT, I found EVERYTHING I needed to know right here on this site!! When I first installed the mirrors I used the eurekaboy.com instructions which is now mentioned here quite often. I got all the diagrams here.
It was fun using the dremel to cut out the holes to mount the door panel switches. A little scary, but not impossible.
Old Dec 29, 2006 | 04:49 AM
ryaneverk2's Avatar
ryaneverk2
Haha, that's the best description right there.
Old Dec 29, 2006 | 08:30 AM
F250_'s Avatar
F250_
I just got off the phone with my local Safelite dealer, and all I can say now is... it's been really fun finding all the stuff, but...
.... it's just as cheap, if not cheaper, to buy the new mirrors complete!
WOW! Safelite wants $100 for each of the heated glass components on these tow mirrors. The non-heated glass components are $61 each, and I'm sure that the heating element will be at least $20 each, but probably more like $30-$40 each.
Therefore, to convert our non-heated non-signal tow mirrors to heated and signaled units, we are looking at:
$ 32 for 2 lights (JCW)
$ 12 for converter element (JCW)
$ 8 estimated shipping from JCW
$122 for non-heated glass components - or $200 for heated
$ 60 estimated cost for two heat elements - or $0 if heated glass is purchased
$ 20 estimated cost of mirror switch
Total = $252 - $272 for both mirrors, depending on the glass purchase
Compare that to what I found yesterday at $105-$145 per mirror COMPLETE plus the $20 switch, which totals $250-$310. This approach also has simpler installation requirements. I can't justify the DIY approach on this one. If/when I get a broken mirror, I'll investigate further. Until then, I'll keep wiping off the frost and making careful turns.
Old Dec 29, 2006 | 08:41 AM
JPLTrucking's Avatar
JPLTrucking
I'm gonna order a set also. JC Whitney should give you a commission Ryan...
Old Dec 29, 2006 | 10:32 AM
empiretc's Avatar
empiretc
I was sure of that, but just because of the heat option.
Old Dec 29, 2006 | 12:40 PM
lionsteve's Avatar
lionsteve
I got a question.
If you don't have power mirrors at all and want to put power mirrors on, which is the easiest and cheapest way to do that?
Steve
Old Dec 29, 2006 | 03:32 PM
ryaneverk2's Avatar
ryaneverk2
Yikes Pete, that heating stuff is expensive. May as well just get new mirrors.
Originally Posted by lionsteve
I got a question.
Steve
Maybe David (empiretc) can chime in... he replaced his non-power, non-folding mirrors w/ new mirrors.
Old Dec 29, 2006 | 07:58 PM
  #28
empiretc's Avatar
empiretc
Steve
There is no real easy way. My mirrors were completely manual and when I first put the newer style mirrors on I only connected the lights and turn signals. After a while, I decided to finish the job.
First off you need to buy the power mirrors. The paddle style are the cheapest and can be had on ebay for around $40 pair. Then you need the switch, I got mine at the dealer for $20.
There are good instructions here for the actual install:
http://www.eurekaboy.com/f250/newmirrors2.htm
Then you need to run all the wires and connect them to the switch as follows (thanks pflueger):
A. Here are the eight tabs on the mirror control switch.
1 - Power (hot at all times)
2 - Instrument illumination
3 - RH (dark green)
4 - LH (red)
5 - vehicle ground
6 - RH & LH (yellow)
7 - LH (dark blue)
8 - RH (purple)
B. Diagram of mirror switch tab layout
______-------______
|....1....2....3....4....|
|....5....6....7....8....|
Unless you go to a junk yard, you are not really going to get a pigtail. I soldered my own onto the switch itself. I also put in a separate switch to turn the heat on and off.
This is all the info I used. It took me an entire afternoon to get all the wiring in, but I works great and I am very happy.
Old Dec 31, 2006 | 04:35 PM
  #29
empiretc's Avatar
empiretc
Steve, have you started on the project?
Old Dec 31, 2006 | 06:27 PM
  #30
Black01F250's Avatar
Black01F250
i have a 01 f250 and want to put the tow mirrows w/ lights on it, but dont need the heat option.
can i get these mirrows with the lights but without the heat... oh and i already have power mirrows
