53-56 Seats
Old May 14, 2001 | 09:16 AM
tlak's Avatar
tlak
53-56 Seats
What are some of the common vehicles that seats are salvaged out of to put in the 53-56. I though about a power bench or 60-40, but need to know some common vehicles to keep an eye out for.
Old May 14, 2001 | 09:24 AM
copeina's Avatar
copeina
53-56 Seats
I have a bench from a mid 60's Ch**y II in mine at the moment.
It fits well and needed only small blocking to set up correctly.
Unfortunately, it is the only non-Ford part in my truck, so despite the fit, I will likely keep looking.
Does anyone have experience mounting newer Ranger benches or Bronco II buckets?
/Kris
Old May 14, 2001 | 12:30 PM
tlak's Avatar
tlak
53-56 Seats
A chevy II bench would probably fall in the catagory like trying to find any old part, either you cant or its shot. The ranger seats sound interesting if they fit right.
Old May 14, 2001 | 06:08 PM
jniolon's Avatar
jniolon
old and in the way
53-56 Seats
I tried a 60/40 bench out of a mid 80's caddy and it was way too much seat for me..
I ended up with a straight bench seat from a mid 80-s chevy truck and it sat well and was a breeze to install...see the article on the FTE tech article site or at http://jniolon.clubfte.com ...
john
Old May 15, 2001 | 07:30 AM
winfordr's Avatar
winfordr
53-56 Seats
I installed 85 Thunderbird buckets in my 54 F100.
The installation wasn't difficult, just used some heavy angle brackets and some 1 1/4" angle to make platform for them.
I did have to remove the headrests because they are too thick and bumped the back window with the seat far enough back to be comfortable.
Also the seats are electric, which caused me a little delay during the wiring phase.
Winford
Old May 15, 2001 | 10:07 PM
tkbowman's Avatar
tkbowman
53-56 Seats
I have a pair of 84 Tbird power buckets for my '56. I've only test fit them, and they appear to be a good fit. I like the center console switches for power door windows and more.
Tim in Burien
Old May 16, 2001 | 10:11 PM
illuminatrix's Avatar
illuminatrix
53-56 Seats
I am in the process of installing leather buckets from a 99 sebring convertable. What I really like is the belts are built into the seats. The newer chev trucks do this to. Try a bench from a chev 2500.
Travis
Old May 17, 2001 | 10:24 AM
copeina's Avatar
copeina
53-56 Seats
Sebring Seats!
Still not Ford, but I like that idea.
Thanks for the tip. Let us know how they look!
/Kris
1950 F-47
1997 F-150XL
Old May 17, 2001 | 02:34 PM
jonjamky's Avatar
jonjamky
53-56 Seats
The seats from a mid-80's ranger will work.you just need to build a frame to raise them up a little.I used square steel tubing.they fit well and look pretty good.I have seen a 54 f-100 dopne with S-10 buckets seats also
Old May 26, 2001 | 10:04 PM
husker's Avatar
husker
53-56 Seats
I installed a pair of front bucket seats out of late model Ch**y van, and they were an easy install. Due to where I wanted them to sit I had to drill new holes in the floor, but I didn't have to build any risers or other brackets. I liked the idea of van seats, as they sit high enought to feel right in a truck. I looked at using the split bench out of a late model f series ford, but they didn't line up with the steering wheel in the truck. It probably would have worked if I was re mounting the steering column. I even took the retractable seat belts with shoulder straps from the van and built mounts to install them in the 54 F250. I feel a little safer that way. Its the only Ch**y stuff on the truck.
Old May 27, 2001 | 10:33 AM
truckfarmer's Avatar
truckfarmer
53-56 Seats
lakecityg
Nov 8, 2022 04:00 PM
96XL
16
Dec 30, 2014 07:52 PM
jeffscott01
Ford Truck Parts for Sale
Apr 20, 2014 11:08 PM
HEAVY100
13
Dec 30, 2012 08:13 AM
Aussie 53
Feb 19, 2009 12:42 AM
