Exhaust clamp question
Old Dec 28, 2006 | 07:26 AM
dzzavid's Avatar
dzzavid
First of all i want to say thanks to everyone, this fourm is awesome and everyone has been very helpful!
i have a quick one for you guys
i am helping a friend upgrade his exhaust on his late 99 (same as mine) but when i try to get the clamp off of the turbo (to the down pipe) it does not budge, i remember on mine i had no problem with it and once i loosened it it slid off, any one have any suggestions on this?
-dave
Old Dec 28, 2006 | 07:28 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
you could try wiggling the pipe from the bottom, tapping on a long screwdriver aimed at the pipe (tap not smack) and soak it down with PB blaster or Gibbs. You will be suprised with just tapping it, it will just pop free after a few minutes. Good luck.
Old Dec 28, 2006 | 07:35 AM
dzzavid's Avatar
dzzavid
sounds good, thanks!
Old Dec 28, 2006 | 09:02 AM
powrstrkn''s Avatar
powrstrkn'
I had to use a wooden surveyors stake and tap the DP with a light hammer to get it to release when I did my 5"
Old Dec 28, 2006 | 09:24 AM
dzzavid's Avatar
dzzavid
sounds goood, i will try this when i get off today.. will it be eaisier if it is hot? like right when i get home?
Old Dec 28, 2006 | 10:41 AM
AustinS's Avatar
AustinS
I doubt it.
It will definitely be toasty if just driven, and hard on the hands for sure.
Just tap on it to persuade it to loosen up.
Be patient and all will be well.
I'm a firm believer in PB Blaster and Teflon lube also.
Austin
Old Dec 28, 2006 | 11:26 AM
dzzavid's Avatar
dzzavid
great i have like 3 full cans of PB blaster at home , i love that stuff
i dont have to worry about flash fires wiht that stuff right on the exhaust do i?
Old Dec 28, 2006 | 11:55 AM
bc56845's Avatar
bc56845
I was sold on PB blaster until I found Howells. TA truck stops sell it. They usually have a shelf with a bunch of other howells products- fuel additive, etc. It makes PB blaster seem like water- it worked really well on my downpipe.
