need some advice
Old Dec 28, 2006 | 12:39 AM
gtlegacy's Avatar
gtlegacy
need some advice
first off i did searches for smoke, and none adressed slight smoke, they all seemed to be excessive smoke.
ok i have a 2000 f250 with the 7.3. i purchased the truck with 85,000 miles and it now has 102,000.it is has no chip, 6637 and 5in exhaust the truck starts fine in the morning, with just a little puff of white smoke. i have began to notice that it smokes slightly at idle and if i gun the gas real quik, even when warm. the smoke is a blue-ish grey color and is mostly noticeable at night when a cars headlights are shining through it. maybe the headlights are exagerating the problem... is any smoke normal? after searching through some threads i thought i should check my turbo, and the exhaust side was dry and the intake side had a little oil but it looked like it was from the ccv. i took the oil cap off while runnig it and there was a little smoke but not excessive. also my rear fender gets black with soot after about a week my questions are,
1 is any smoke normal out of the tail pipe?
2 could it be injectors, it runs fine?
3 am i being paranoid and should i just run it?
Thank you for your time and advice
Old Dec 28, 2006 | 12:52 AM
CSIPSD's Avatar
CSIPSD
Are you SURE its not chiped? Or a program left in it?
Old Dec 28, 2006 | 12:56 AM
gtlegacy's Avatar
gtlegacy
i dont think it has a chip because it feels stock and it doesnt have black smoke on acceleration.
Old Dec 28, 2006 | 12:58 AM
CSIPSD's Avatar
CSIPSD
I would just run it. If you know someone that can do a buzz test and Cylinder Contrubution test I would do it just for S and G... but dont pay to get it checked out at this point. Some smoke is normal.
Old Dec 28, 2006 | 06:22 AM
Kwikkordead's Avatar
Kwikkordead
You shouldn't have oil smoke once it's warmed up.
Some black smoke is normal.
Old Dec 29, 2006 | 02:00 AM
gtlegacy's Avatar
gtlegacy
could a bad injector cause the engine to smoke blue/grey, also the exhaust smells very strong...
Old Dec 29, 2006 | 07:13 AM
Uzumati's Avatar
Uzumati
Check These out: Something to check
https://www.ford-trucks.com/forums/5...ak-update.html
https://www.ford-trucks.com/forums/5...hing-else.html
