witch cools the trans fluid first
Old Dec 27, 2006 | 09:04 PM
myakkacracka's Avatar
myakkacracka
I have a 96 f-150 4x4 with a 5.0 and a 4r70w trans. it is also equipped with a factory instaled trans cooler and i was wondering if the trans fluid goes into the radiator first or the cooler first
Old Dec 27, 2006 | 09:13 PM
pfogle's Avatar
pfogle
If it has a trans cooler I'm not sure it goes to the radiator at all. If it does then it goes through the radiator then the cooler.
Old Dec 27, 2006 | 09:25 PM
myakkacracka
ya it goes to the trans to i remember the lines when i replaced my radiator. thanks for the help
Old Dec 27, 2006 | 09:26 PM
myakkacracka
i mean it goes to the radiator
Old Dec 28, 2006 | 08:01 AM
EPNCSU2006's Avatar
EPNCSU2006
I seem to remember that the fluid should go to the external cooler first, then go through the radiator so that on cold days the fluid wasn't being overcooled.
Old Dec 28, 2006 | 09:47 AM
pfogle's Avatar
pfogle
I could see that happening, but I've noticed that on the ones I've seen that the lines go from the trans to the rad, then to the cooler.
Old Dec 28, 2006 | 01:30 PM
kell104's Avatar
kell104
I am not sure if ford did it different but I have installed aftermarket coolers before and they all said to hook the cooler up after the rad.
