92, e40d fluid
Old Dec 27, 2006 | 04:00 PM
Gold Dog's Avatar
Gold Dog
92, e40d fluid
Hi
I have have a 92 F-350 with 58K on Motor / Trans. I have noticed a Shudder just befor it shifts into OD. I got the Truck used so i dont thank the Fluid has ever been changed. My question is can i use Mercon V in this Trans, or should i stay with the factory Mercon 2 i thank it is? Also i have heard a few people say not to change the Trans Filter, Thanks for any advice
Old Dec 27, 2006 | 04:42 PM
Casey's Avatar
Casey
Ford is ending MERCON fluid. You'll still be able to get it for most of 2007, then it's gone. They have changed MERCON V so that it is compatible with the E4OD. So use either one.
Ford doesn't have a recommended mileage to change the filter. I change mine every other fluid change.
CLICK HERE for a good way to change the fluid.
