how to test a idm
Old Dec 27, 2006 | 01:04 PM
FIREFIGHTERHFD61's Avatar
FIREFIGHTERHFD61
how to test a idm
can someone tell me how to check the idm to see if it is bad and also check the wiring harness i get horrible fuel milage about 10 mpg and hard starting and low power it is a early 99 f-350 7.3
Old Dec 28, 2006 | 07:59 PM
Fire Rooster's Avatar
Fire Rooster
Buzz test from dealer, also have them scan it
Old Dec 28, 2006 | 08:15 PM
Uzumati's Avatar
Uzumati
You can ohm out the harness and injectors from the IDM connector. PM me your email address and i'll send you the pinout.
Old Dec 29, 2006 | 01:07 PM
FIREFIGHTERHFD61
HARLEY55_1@HOTMAIL.COM
Old Dec 29, 2006 | 01:12 PM
Uzumati's Avatar
Uzumati
I'll send it tonight when i get home to my manuals. you may want to edit your post and remove your email address to be safe.
Old Dec 29, 2006 | 02:43 PM
pullinair's Avatar
pullinair
Hears a dumb question that i should know by now- Is the IDM built into the PCM? If not were is it located? Is it another name for the PCM?
Old Dec 29, 2006 | 03:11 PM
Uzumati's Avatar
Uzumati
IDM provides 115vdc to the injectors so Ford wisely moved it out of the PCM. If you remove the driver side wheel well liner and look up to the right it is on the inner fender.
PCM Tells IDM to fire at 12vdc and IDM sends 115vdc to the injectors
Old Dec 29, 2006 | 03:28 PM
pullinair's Avatar
pullinair
Good thinking Ford, gettin all of that voltage out of there! I've owned my truck for three years and now i know. Is there any tinkering ,maintanence, mods, i can do to it?
Old Dec 29, 2006 | 03:45 PM
Uzumati's Avatar
Uzumati
I think it was called the Joe Servo IDM mod. it raised the voltage to around 140 volts supposed to make the injectors fire quicker.
