Sponsored by: Real Truck
Ball joints
Old Dec 27, 2006 | 12:42 PM
satcom40's Avatar
satcom40
Cool Ball joints
Well it’s my turn for problems. The dealer just called saying that I need ball joints all around. I have an warranty but is was one of those aftermarket one, and if I’m with in 40 miles of the dealer I brought it from I have to go there to get warranty work done. There only 28 miles away. I took it in for 60,000 mile service on the transmissions and have the brakes look at , I do the oil, fuel and air filter’s my self. So now I have to go to the other dealer.
So how long does it take to replace the ball joints all 4, upper and lowers ?
I guess it my fault I didn’t get the FORD ESP warranty.
OK I guess that will do for the venting. John
Old Dec 27, 2006 | 02:08 PM
3094's Avatar
3094
one day for ball joint, get all done, Ford dealerships care double of what reputable local shop charged at 48 K, truck now has 70K, mechanic says this is common, excusion was in having them done at 28K
Old Dec 29, 2006 | 06:38 PM
ken kenmnedy's Avatar
ken kenmnedy
03 f250 sd5.4 ec just got mine done at 63000 miles went to privet shop that does fleat work got better than ford ball joint drives like new agin ford changed first set at27500 these new ones are even greaseable plow truck hard on ball joints
Old Dec 29, 2006 | 06:41 PM
trike1946's Avatar
trike1946
Mine were bad at about 56k. One day job.
Old Dec 29, 2006 | 06:48 PM
ken kenmnedy
Smile shop time
took shop 4 hrs. I watched them the whole time new stabellizer links bushings and stabilizer shock 4wheel alienment all better now
Old Dec 29, 2006 | 06:52 PM
wcurtis's Avatar
wcurtis
do a search on ball joints, there is a lot of imformation on the forum
Old Dec 29, 2006 | 11:57 PM
satcom40's Avatar
satcom40
Took the truck to dealer and they did the job in one day. So how long till I need a new set. hopefully more then 60 K. thank for the feed back. John
Old Dec 30, 2006 | 04:59 AM
trike1946's Avatar
trike1946
John, what kind did they install, and do they have grease fittings? That will give you some idea how long they will last.
Old Dec 30, 2006 | 06:40 AM
3094's Avatar
3094
Only private shp was quoted at using grease fittings in my area, Ford puts in OEM & their price was double, plus ford claimed they couldd not align the truck, private shop included this, had truck in one day,
2001 F350 4X4 SC Dually, 70K, 7.3PSD
