bleeding to death
Old Dec 27, 2006 | 08:15 AM
94Ford250's Avatar
94Ford250
bleeding to death
I have a 94 F250 diesel 4x4. I changed the clutch master cylinder on it this weekend and now I can't seem to get it to bleed. I changed the slave cylinder on it a few months back and it was a pain to bleed but it eventually did. I have no pressure in the pedal at all. The instructions say to bleed it from the slave cylinder. When I open the bleed screw on the slave, sometimes fluid squirts out and other times it dribbles out. Could there be an air lock? Does anyone have a near foolproof way of bleeding these systems? Any help would be greatly appreciated.
Old Dec 27, 2006 | 01:54 PM
zekeskid's Avatar
zekeskid
go to local auto parts store and spend 15-20 dollars and buy a vacuum pump kit. it attaches to the bleeder screw and sucks the fluid through the system and ino a container so it can be reclaimed. I've used it on brakes and it works great.
Old Dec 27, 2006 | 03:05 PM
94Ford250's Avatar
94Ford250
Tthere is no bleeder screw persay. it is an allan key screw on top. It is not like brakes where you use a tube and a wrench. Thanks for your input and I'll check with the auto parts store in town to see if they make one for that application.
