Need Help!!!!!
Old Dec 26, 2006 | 09:15 PM
051f's Avatar
051f
Unhappy Need Help!!!!!
my son was changing oil and filter on 1998 exped. 4" threaded pipe came off with oil filter attached to it. Assume this pipe goes though oilcooler adapter.
Can it all just be put back up and pipe rescrewed to engine block????
Old Dec 26, 2006 | 11:52 PM
thefarelaneman's Avatar
thefarelaneman
Yes just screw it back in and snug it tight, crank and check for leaks
Old Jan 2, 2007 | 12:57 PM
051f's Avatar
051f
Need help reply
Thank you for the info. If this happens to someone else, look inside the threaded pipe, mine had a hexagon shape about one inch inside. I insterted a bolt that fit it, put several nuts on the bolt and attached another bolt to the last nut. I the used a deep socket and put the pipe back though the oilcooler and with the deep socket tighten everything back up to the block. This worked great and we took our trip about 1200 miles, stopping many times to check the oil and for any leaks. Thanks to all that replied with great help.
05 f250 6 inch lift
Sep 25, 2012 08:20 PM
AndeyHall
Jul 11, 2011 10:32 PM
pinesman
Feb 2, 2007 11:08 AM
JohnnyMack
Aug 18, 2002 02:01 PM
nissanjon
Jul 29, 1999 10:52 PM
