Aerostar Ford Aerostar
axle ratio question
Old Dec 26, 2006 | 06:11 PM
ken1mod's Avatar
ken1mod
axle ratio question
The simple question is this: when buying a new vehicle, which will have longer transmission life, the one with 3.23 or 3.73 axle ratio. Assume same engine and usage.
I think the numerically higher ratio, 3.73, because the transmission will see lower torque (stress). What do you think?
Ken
Old Dec 27, 2006 | 12:30 AM
Pablo-UA's Avatar
Pablo-UA
It depends on condition of use. For urban areas 3.73 is better, but for Hightways -3.23.... I have 3.45 LSD with manual tranny. I have tranny of Volga, but Tires of volga are bigger and Volga has 3.9 rear diff. So after 1 minute calculetions I swapped my 4.1 diff to 3.45 and now I drive faster. But speedo read incorrectly.
Old Dec 27, 2006 | 04:55 AM
ken1mod's Avatar
ken1mod
I completely agree Pablo. But the question is which ratio will be easier on the automatic and make it last longer.
Ken
Old Dec 27, 2006 | 05:27 AM
Pablo-UA's Avatar
Pablo-UA
What tires size you have? 215/70R14? I have 225/60R15....
Old Dec 27, 2006 | 05:33 AM
ken1mod's Avatar
ken1mod
225/60 r 15
Old Dec 27, 2006 | 05:45 AM
Pablo-UA's Avatar
Pablo-UA
With A4LD 3.73 ore 3.45.... But do you drive you van full of people ore luggage? if yes, use 3.73, drive empty van - 3.45
Old Dec 27, 2006 | 03:41 PM
xlt4wd90's Avatar
xlt4wd90
Ken,
My intuition is the less you load the transmission, the longer it should last. So with a lower gear ratio, but keeping the same tire size, you get more torque, and thus less load, on the transmission. This should make life a little easier on the clutches and bands. But the entire assembly will be turning a little faster, so there will be a little bit more wear on the gears and bearing surfaces, but probably not noticeable.
2gumby2
2015 - 2020 F150
Jul 23, 2016 08:26 AM
F-250beast
Nov 14, 2010 11:52 AM
jschira
Feb 7, 2010 09:02 AM
Packard V8
Oct 27, 2009 06:20 PM
Toreador
2004 - 2008 F150
Jul 16, 2004 11:07 PM
