I definitely realize that I am for not knowing this but here is my dilemma.
I've got a `99 7.3L PSD, dually and my driver's side marker light (the one that is on the flared rear fender is out. Yup, you guessed it, I dont' know how to replace it .
The problem is that I've had the truck for a year and this hasn't come up before. Therefore, I'm not sure how to do it.
Can someone steer me in the correct direction as to how to remove the yellow lens cover so that I can get to the bulb?
From what I can tell in the manual, you need to take loose the inner fender shield, work your hand up in behind the light, and unplug the light and socket out of the assembly from the rear. Then take the light out of the plug/socket.
