Right rear wheel will not rotate
Old 12-26-2006, 11:21 AM
mr_jor's Avatar
mr_jor
mr_jor is offline
Loaded the truck this morning to go dump the Christmas recyclables, aka GoodWill run. Started the truck, released the parking brake and went to pull forward. Truck does not want to move, tried it in reverse, still nothing. After a little help from the the wife, I figured out the right rear wheel is NOT rotating, I can get the left to spin, and still nothing from the right.
Any assistance would be appreciated. I am contemplating taking the wheel off, but I would need to go get a Haynes manual. Not sure if I could fake my way through it.
Thank
Jim
Old 12-26-2006, 12:07 PM
mr_jor's Avatar
mr_jor
mr_jor is offline
Just some more details
The truck is a 2004 Ranger. It last moved Friday (22DEC) it was raining. It also rained one other day since 22DEC. The truck was parked on a slight incline.
Old 12-26-2006, 12:42 PM
Dave257's Avatar
Dave257
Dave257 is offline
Sounds like the emergency brake is stuck/froze on that side, whats the temp like today?
Dave
Old 12-26-2006, 12:47 PM
Erk469's Avatar
Erk469
Erk469 is offline
I would have to agree with Dave257
Old 12-26-2006, 12:54 PM
mr_jor's Avatar
mr_jor
mr_jor is offline
This thing is killing me
The temp is 55.
I figured I would try to remove the brake drum and see what's going on, or not. I went and bought the Haynes manual and a brake tool (little lever looking thing). I cannot even get the drum to come off. I followed the instructions in the manual and the damn thing won't budge.
If I can get the truck to move its going to the shop, but until I get this sorted out its going nowhere.
Jim
Old 12-26-2006, 01:22 PM
twoj05's Avatar
twoj05
twoj05 is offline
The left rear e-brake cable on my '03 wore through and rusted up, I suspect the same has happened to yours. You may have to get aggresive with the star wheel inside the drum (brake lever) to loosen it. Good luck.
Old 12-26-2006, 03:00 PM
mr_jor's Avatar
mr_jor
mr_jor is offline
Problem Fixed
I messed with the star thingy, tried to relieve all the tension on the pads. Even after bottoming it out, the drum still wouldn't budge. I finally took a couple large flat tip screw drives and pried the damn thing off. Once I could see into the drum there were a couple parts that had apparently busted, so I finished the prying method. Looks like there are a couple busted springs and other assorted metal parts. Not sure what caused it, maybe just age. The only other thing I can figure is I got hit on the right rear side over a year ago; resulting in some minor body work. Not sure if the two are related.
Anyway, truck headed to the dealership on Friday to get fixed correctly. I would like to tackle it, but brakes are important to be done right and I just don't have the time. If I wasn't so conscientious I would just keep driving it with no right rear brake guts.
Thanks for the help, I should spend more time on the list, as I learn something new everytime I visit.
Jim
dannojames
Escape & Escape Hybrid
08-26-2014 06:27 AM
PRIMERTT
1947 and Older Ford Trucks
05-24-2012 11:14 AM
Chad149
Michigan Chapter
03-01-2012 11:32 AM
jetdoc
26
12-27-2010 04:55 PM
forddude05
10-20-2003 08:10 PM
Quick Reply: Right rear wheel will not rotate
