01CROBRA, Thanks for your responce on the 305/65/18 tires. They do look great. I have that same color 4dr but the bumpers are black and its an 05. I also have an ARE Z series cap that levels the truck. With that being said, if I add the leveling kit then I'm going to have to add the ADD LEAF system to the rear to keep it level.That bull bar looks great also but in the state of N.J. it is illegal to block the front liciense plate which are manditory. The bull bar seems to loose it's look without that lower plate.
I put on 305/55/20's which i think are the same size and on the factory 20's they rub at full steering lock with the AS 2" kit. are there any small spacer kits available?
You are not gaining much moving to the 305's here is a break down
Stock 275/65/18
Sidewall - 7 in
Radius - 16 in
Diameter - 32.1in
Circum - 100.8
Revs/mi - 629
305/65/18
Sidewall - 7.8in
Radius - 16.8in
Diameter - 33.6 in
Circum - 105.6
Revs/mi - 600
Your speedo will be effected.
What is it that you are trying to say? I think that these tires look MUCH better due to their size and will perform better as well. It may not sound like much when you put it in writing but their certainly is a difference when you put them next to each other.
