4x4
Old Dec 25, 2006 | 04:22 PM
Redneck1465's Avatar
Redneck1465
4x4
I have a 1985 F150 Extended cab 8 foot bed with a carborauted 351 W. It is two wheel drive. I can get my hands on a 1993 or so F150 4x4 for real cheap. I was wondering if I could put my body from the 85 on the 4x4 frame from the 93 truck. Also, will the 4x4 work with the carborated 351??? The 93 F150 has a 5.0 I believe.
Old Dec 25, 2006 | 07:27 PM
Mil1ion's Avatar
Mil1ion
If you go Carbureted you will have to dump the Computer controlled devices.
Fuel delivery will be the biggest difference.
EFI requires 40 psi
Carburetion requires 7-9 psi
Oil pressure actuator switch with fuel pressure regulator is required
Old Dec 26, 2006 | 04:33 PM
Redneck1465
I dont want to keep the engine from the fuel injected truck. All I want is the trans and the transfer case. I want to mount the carborauted engine to the 4x4 trans and transfer case. I am going to get rid of the fuel injected engine. I am going to pull everything off of the 4x4 frame including the engine and just leave the trans and transfer case and the frame. I want to then put the carborauted engine in and put all of my body parts on the 4x4 frame. So baisically my question is can the 4x4 trans and transfer case match up and work with the carborauted 351??
Old Dec 26, 2006 | 05:07 PM
wizzard351's Avatar
wizzard351
if the 4x has a 302 your 351w will bolt to the trans.
Old Dec 26, 2006 | 06:50 PM
Mil1ion's Avatar
Mil1ion
Sorry, I thought one was EFI (The 93) and you were putting the Carbureted engine in this truck.
Yes the 302 and the 351W share the same trans bolt pattern
garrett_8
May 2, 2013 02:11 PM
bearcats101
24
Jun 7, 2011 04:32 PM
93fordflareside351
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Apr 7, 2008 08:46 PM
93fordflareside351
Feb 27, 2008 01:06 PM
fishmanndotcom
Nov 8, 2001 08:11 PM
