Crazy ignition problem...
Old Dec 24, 2006 | 04:36 PM
tippi98custom's Avatar
tippi98custom
ok, my name is Aaron and im new to this site but i have a problem with my truck. I have a 1997 f250 ext cab with the 5.4L in it. It is the old f150 body style. but i just put a 3 inch body lift on it and i went to start it up because the battery went dead while i was doing it cuz i left doors open and listengin to the radio and whatnot. but i went to jump the battery and i then go turn the key and it slllloooowly cranks, hardly at all. but i know that is because the jump it needs to be recharged, but the big problem is that once turned the key back it still was cranking over....any ideas, because im afraid to actualyl jump it and it not want to stop cranking over and i end up breaking things like a starter or whatever...
Old Dec 25, 2006 | 12:34 PM
Franklin2's Avatar
Franklin2
Low voltage will sometimes overheat the starter relay contacts and make them stick. I believe your truck has a starter relay like the older Fords, and also a starter solenoid on the starter itself. Either one could be stuck.
If it unsticks itself, just charge the battery up overnight on a small charger or get some decent sized jumper cables and jump it. If it's still stuck, take the handle of a screwdriver and rap on the starter relay(I believe it's mounted on the firewall) and or on the starter solenoid on the starter itself, to try to break it free.
Old Dec 25, 2006 | 06:45 PM
tippi98custom
ya thaks alot, that was the problem and it works perfect now
danielwd
1983 - 2012 Ranger & B-Series
Jul 11, 2014 08:20 AM
DoubleAr0n
28
Jun 2, 2014 10:22 AM
Singing River Farm
18
Jan 25, 2014 03:51 PM
sbjess03
Oct 26, 2010 02:07 PM
AaronW
Sep 11, 2001 02:37 AM
