HELP!!! i'm confused
Old Dec 24, 2006 | 10:17 AM
DJdemon6696's Avatar
DJdemon6696
Unhappy HELP!!! i'm confused
1990 F250 351W EFI ....why after 6 - 12 months thr sparkplugs 4 and 8 its the ones more closere to the fire wall the sparkplugs fails beacuase they are covered in oil... i know thats the pistong rings but why only the pistons nr 4 and 8 ? ? and the other ones are healty ! ? im confused do i need to chage the piston rings ?
Old Dec 24, 2006 | 10:48 AM
baddad457's Avatar
baddad457
Could also be the valve seals failing too. Or the PCV valve sucking too much oil. I don't know where the PCV goes into the intake tract, but if it primarily goes into runners 4 & 8 then your problem's more likely the PCV doing it.
Old Dec 24, 2006 | 11:55 AM
HemiEater's Avatar
HemiEater
I've seen broken pieces of valve seals clog the rear drain holes in the heads could be getting in that way too.
How many miles on it?
Old Dec 24, 2006 | 12:47 PM
DJdemon6696
150.000+ miles
Old Dec 24, 2006 | 01:49 PM
payday33's Avatar
payday33
I do not know about a 351, I do know that a 302 has this problem if the rear gallery oil holes are clogged with sludge. The oil will fill the valve cover and drain down the valve stems to the top of the cylinders.
Old Dec 24, 2006 | 01:52 PM
HemiEater's Avatar
HemiEater
same basic head....
Old Dec 26, 2006 | 03:17 AM
DJdemon6696
I FIXED THE PROBLEM GUYS!!!!! it was the frkn PCV valve i never ever had changed it it was the stock one from 1990 lol! it TNX allot!! " baddad 457 " and " hemi eater " now the engine is healty *** a horse just a little rich...
