95 F150 Ignition Switch - Need Help
Old Dec 24, 2006 | 04:36 AM
marragtop's Avatar
marragtop
I have a 95 F150 5spd and there is something wrong with the ignition switch. The switch turns even with no key inserted, and the steering wheel never locks. Will a new ignition switch solve this problem? Also, how hard is it to put the switch in, and do I need to be concerned with the air bag? Thanks for any/all replies.
Old Dec 24, 2006 | 02:54 PM
Lazy K's Avatar
Lazy K
I would think a new switch barrel would solve your problem. From reading other posts if you look underneath the steering column where the key goes you should see a very small hole. With the ign. switch turned to "on" insert a fine nail or drill bit into the hole and push in and hold, you should then be able to withdraw the barrel. Hope this helps.
Old Dec 24, 2006 | 07:05 PM
marragtop's Avatar
marragtop
Thanks for the reply, my main question is... do I need to be concerned about the air bag system? The Haynes manual makes no mention of it. thanks...
Old Dec 24, 2006 | 07:10 PM
brown 4x4's Avatar
brown 4x4
No, it won't affect the air bag at all.
Old Dec 24, 2006 | 09:30 PM
quicklook2's Avatar
quicklook2
ford manual suggests disconneting the battery when replacing lock cylinder.
Old Dec 25, 2006 | 12:10 AM
78_79ford's Avatar
78_79ford
I have the same problem with my ignition, it fires up without the key, I'm gonna get fixed before I move.
Old Dec 25, 2006 | 01:40 AM
kell104's Avatar
kell104
I would definately disconnect the battery. Even though it is very unlikely you don't want that bag going off on you. I had one go off in an accident once and it sucked worse than the actual impact. the burns were horrible. Imagine a rug burn X 100. You may have to jiggle the lock cylender a little bit pulling in and out. It will give up eventually
Old Dec 25, 2006 | 10:03 AM
quicklook2's Avatar
quicklook2
batt. disconnected
key to run position
1/8" drill in hole below key at bottom of column
remove
put new one in
turn to off
reconnect batt.
go have beer
